bspeedy
Platinum Member
- Joined
- Dec 18, 2012
- Messages
- 954
- Location
- Upstate SC
- Tractor
- Kubota L4330, Ford 1700, JD 2210, Takeuchi TB135 Excavator
I've had good luck with a product from Loc Tite called 'Freeze & Release'. It's basically a penetrant spray that rapidly cools the item being sprayed.
My method:
Remove grease fitting, dig hardened grease out of fitting, get grease to flow to grease fitting, set aside.
Use dental pick or other small tool to pick away hardened grease down to the surface of the pin.
Spray penetrant into the hole and allow to penetrate. Also may be helpful to spray penetrant around edges of the joint, anywhere it can enter the area between pin and bushings.
Re-install grease fitting and apply grease with grease gun.
Grease regularly!
I have had a better than 90% success rate with this method without removing pins. Of course, removing pins will allow you to see if they are damaged, but it's a pain in most cases.
Good luck.
My method:
Grease regularly!
Good luck.
