Zero Turn electrical issue
/ Zero Turn electrical issue #1
goober33
meridian, ms
Gravely PM260Z
Hopefully you guys can help me fix a nagging electrical problem with my zero turn mower. My problem, or I should say "problems" are: 1, the PTO switch was bad. It was replaced and worked fine for about 2 months. Then while mowing one day the engine suddenly stopped. I put the brake on safety and the engine started right back. I let off the brake and the engine died. I located the brake switch single pole, Delta Systems - and it appeared to be ok. The PTO switch which is only 2 months old is also by Delta Systems. The seat switch is a closed circuit as the mower was purchased used. The previous owner by passed the seat switch no problem for at least 1 year. So, in diagnosing the problem I can hold the brake switch on and the engine runs fine and the control bars work fine as I can transport around the yard. The problem now is when I place the PTO switch to the on position, the engine dies. I plan to re-install all the safety switches but first I need to find out what痴 going wrong. Any ideas?
/ Zero Turn electrical issue #2
I'd check that the seat switch jumper didn't come loose ( open circuited)
Example: I can imagine a scenario where if the seat is not occupied (or seat switch is bad) engine will only run with safety brake on, or if seat is not occupied (or switch is bad), PTO cannot be turned on/engine stops.
$.02
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
1983 John Deere 2940 Tractor (A62613)
1983 John Deere...
2010 Chrysler Town and County Van (A61574)
2010 Chrysler Town...
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
1993 Transcraft 38Ft Step Deck trailer (A64194)
1993 Transcraft...
