Zero Turn Mower?
   / Zero Turn Mower? #31
I believe a lower end residential ZTR will work just as good as the expensive ones. It's just that they aren't going to hold up to the wear and tear as well. If you're only doing 1/2 acre per week, save your money.
   / Zero Turn Mower? #32
I've heard the statement many times that ztr's are terrible on slopes. My personal experience is the opposite. My property is mostly flat, with the only sloped areas being where the property meets the road at the lot corners. These areas are about 5'-6' below the road surface with the hypotenuse being about 10'-12' in length. Don't know what % grade that makes it as I don't feel like dusting off my trig. Anyhoo, I own a Dixie Chopper Silver Eagle with Turf Boss III tires. I can stop, back up, turn, drive up, down and across while on these slopes without any traction problems whatsoever. I will say that these tires can be a bit of a double-edged sword in that when the ground is really wet, any semi-aggressive turn will tear the turf up pretty good. When it's dry, no problems at all.
Google Image Result for http://blog.blackhawklawn.com/wp-content/uploads/2011/06/97200.jpg
   / Zero Turn Mower? #33
I have a Ferris ZTR and a Craftsmen. I will use the ZTR for everything EXCEPT on the slope that goes down to my lake. It just does not feel as stable in that situation.
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Booster Cables (A59230)
Booster Cables...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- DEMO UNIT (A56438)
Greenworks...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
