Zero turn mowers on hills
   / Zero turn mowers on hills #1
HiddenHollow
New York
Kubota L3400 Extra Power, Ford 8n
Hello everyone, Looking for some info on operating a zero turn mower on slopes. We are looking at getting a zero turn mower for our property and I was wondering how they do on a hill. We have some slopes that can't be mowed up and down the hill because there is a creek at the bottom. I have sat on a few and they seem a little top heavy. Any input would be greatly appreciated.
   / Zero turn mowers on hills #2
There are going to be some people that say any slope is too much. Then there are going to be some that say don't worry about it because they have no problem mowing the drainage ditch out by the road.
Here's the thing: The front wheels caster. They don't have any positive steering - or in most cases braking - control whatsoever. So mowing sideways across a slope will cause the mower to turn in the direction of the slope. Imagine pushing a shopping cart across a slope. It will attempt to turn downhill. That's the effect I'm talking about.
Now if the slope is mild, that downhill steering tendency is easily countered by slightly altering your control inputs. It's no big deal and you quickly learn to just correct for it keep on mowing. But when the slope gets steeper, it becomes a chore at best.
Now let's consider a more dangerous scenario. Steep enough that you actually slide. The amount of slope needed to slide is of course variable. What kind of tires do you have? Is the grass wet with dew? Are you using abrupt control inputs? Anyway if you start sliding out of control most zero-turn mowers don't have much in the way of ability to regain control except to just wait until you've reached a spot with less slope. And the last place you want that stopping point to be is in your creek.
I'm not going to tell you what to use for your mowing duties. Just wanted to paint a picture of what the zero turn mowers are - and are not - capable of.
xtn
   / Zero turn mowers on hills #3
Here in WV almost everything is a slope to some degree or another. There are some places that are flat but not many. I tried ZTR mower and it didn't turn out well. I have read the best results on slopes with a ZTR is to get a wide stance(width) on the rear wheels. This allows a better resistance to the front pulling down hill.
The unit used was a Bad Boy that is probably their biggest residential mower at 60" and a 28HP motor.
I could fly on the flat areas with a fantastic cut but the sloped areas had to be cut up and down or I could keep the front on track. I have a few places that the front would pull it all the way around and start down hill and I have a drop off before the creek.
This is why I didn't keep the ZTR and got a BX 1500 Kubota with 4WD. The BX is not near as fast as the ZTR but is safer much safer.
Some of the pro grade ZTRs may work for you and I would look there and talk to those that use them in an area like yours. Like I said before it will be the unit with a wide wheel spacing in the rear that may work for you.
Thanks for the input. I will keep it in mind.
   / Zero turn mowers on hills #5
xtn
Good points. I'll add that the rear wheels will tend to peel out and send the machine sliding down hill if you turn from going sideways to uphill. Once you break traction, its hard to get it back if the hill is steep enough.
Like dex3361 said, a wider stance will definitely help with feeling more stable. That's one of the things that caught my attention about my Hustler Fastrak - It feels very wide and stable.
   / Zero turn mowers on hills #6
I own a Hustler SuperZ zero turn. This mower can go very fast. We have a pond at our house and steep hill going to it. We stay away from the slope when it is the least bit wet. These mowers have so much power that it is hard to tell when you are spinning then you start slipping like you are on ice.
A friend that mows a lot of lake lots told me to back down the slope and mow going up. It works but very scary backing down as close to water as you dare but it does climb the hill without spinning. I have tried mowing sidehill but once it starts spinning you are headed downhill with very little control.
   / Zero turn mowers on hills #7
Of course it depends on how steep the hill is. It is a major issue with a zero turn mower. I have a couple of slopes in the yard here that I have to mow by backing down and then mowing going uphill, back down the next strip... Even going forward downhill they don't have good control, but then I do have to admit that even a CUT has to be used in 4WD on that hill. A couple of times the CUT was in 2WD and slid down the hill.
Ken
   / Zero turn mowers on hills #8
What I can't figure out is how the highway mowing crews get away with using ZTR's? I watch a crew mowing the local roadside with slopes I wouldn't even tackle with a tractor using Dixie Choppers and they don't seem to have any problems. The only unusual feature I notice on these mowers is that they have bar tires.
How do they do it? Do they load the tires? Is there something about Dixie Choppers that makes them work better on hills?
I would love to have one for my place, but I have 20 degree slopes everywhere and am scared to even try one....
   / Zero turn mowers on hills #9
i have a Dixie Chopper 60" cut. They are tricky on side slopes because of the front wheels being casters. Mine has knobby atv tires on the back and holds fairly well. If I were to be mowing mostly sloped ground I would get a mower built for it. Sorry I do not know the brand name but I have seen them at the Clinton County Fair. They appear to be zero turn but have only one front tire that is more like a ball so it grips with its side or anywhere around it. They must have some sort of leveling system to keep the seat and engine somewhat horizontal.
   / Zero turn mowers on hills #10
I hear this all the time and my answer is always the same; a mid mount ZTR is not very good on slopes. However a front mount ZTR will easily mow hills that most 4wd (or front wheel assist if you want to be PC) can't mow. After having a mowing service, I kept two front mount Grasshopper mowers from the business. Please note; for a high quality mower like these and a front mount mower, you will NOT be buying an inexpensive 'residential' (read; replace every few years) mower. About the only mowers that will mow on steeper slopes than front mount Grasshoppers would be the Powertrac type mowers. On a scale of 1 to 10 on hill stability, I'd give front mount Grasshoppers a good solid 8+. I'd rate Dixie Choppers (great mowers BTW) about a 7 on that scale. I'd give your standard inexpensive entry line ZTR from a box store about a 2 on tha scale. There is a huge difference.
2010 Astec Underground RT660 4WD Trencher Backhoe (A55787)
2010 Astec...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A55852)
2007 Ford E-450...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
2001 Blue Bird Commercial Portable Office Bus (A55852)
2001 Blue Bird...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
