ZETOR 3320
   / ZETOR 3320 #1
texana1
ZETOR 3320
Stuck Tractor and pulled the Hydraulic LINE broke going to pump from Hydraulic Tank,,,,,repaired the line low pressure and filled the tank with Hydraulic oil and now will not build up any pressure for front end Lowder,,,NO Hydraulic OIL IS MOVING
   / ZETOR 3320 #2
Dumb question. Any idea how long the engine ran AFTER the line broke and before you figured out the pump wasn't getting any oil? Running a pump dry can do a lot of damage in a short time. Have you tried removing a line from the top of the pump and slowly adding some oil into it, then trying it again. Sometimes a dry pump will come back after that if you get the gears wet enough to pick up prime.
Wood Bench (A53316)
Wood Bench (A53316)
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
1996 Ford F Series Distribution Truck (A47477)
1996 Ford F Series...
