sa324owner
Member
I bought my SA324 back in April and I've been scouring the Internet ever since looking for modifications to make. I wanted to share what I've done so far and I'd like to see what other people have done as well.
Fabricated 2 Inch receiver in place of original drawbar. Most accessories I already have for my truck fit a 2" receiver so this was far more useful to me. Used a cargo carrier I fabricated for my wife's old car to carry a large cooler. We would fill the cooler full of water for watering plants around the yard.
T-slot aluminum for ROPS-mounted lights. T-slot aluminum for versatile mounting for shovels/rakes/gas trimmer, etc. Wiring for lights is fully integrated into the main wiring harness at uses fused accessory circuit. Switch fits perfectly in pre-existing hole.
Obligatory steering knob.
Cross drawbar from TSC. I drilled out the two outer holes to fit some shackles. Seems to work well for general purpose stuff, including pulling small trees with the 3-point.
Last, and certainly not least, a lever in place of the brake pedal-actuated differential lock. In my opinion, this (or something like it) is how the tractor should have come equipped originally. The lever gives a MUCH improved positive feedback on whether or not the differential lock is engaged. As an added bonus, the lever will engage the lock if moved forward OR backward. The 3-point sliding lock can also be used to lock the new lever in the locked position if need be. I rebent the 3-point height control lever so the handle grip angles inboard so the two levers do not interfere with one another. The lever is currently unfinished. I will likely 3D print a handle grip similar to what's already on the machine. Since the brake pedal no longer does double-duty, I took all the slack out of the braking mechanism. The brake now operates as you'd hope/expect.
Now... show me what you've come up with!
