Yanmar YM135/YM155 Parts Cross-Reference
   / Yanmar YM135/YM155 Parts Cross-Reference #1
gmiller001
Yanmar YM 135
In the process of putting my old YM135 back together, I've put together a list of parts. Some of this info is scattered around on the Internet, but some of it is info that I had to figure out on my own. I figured that putting all of this together in one place could help someone else.
Part NameOriginal Yanmar Part #New Part #Notes
Cooling Water Joint (radiator hose connector)124160-4948084736Available at O'Reilly, Advance, and NAPA
Alternator (external rectifier - for 4-wire rectifier/regulator)124660-7799110941NWAI brand
Regulator (replaces 4-wire design)121520-77710CH15589Search for a regulator for a YM220 or a Deere 650. Also used on Kubota and Grasshopper.
There's usually a dozen for them for less than $40 on Ebay and Amazon
Yanmar Lime Green Paint (early USA market Yanmars)???CML-6054Van Sickle Tractor and Equipment Enamel for Clark Forklift
Air Filter (donut style)12460-1251042710
PA1832
Wix
Baldwin
Oil Filter124450-3510051064Wix
Fuel Filter104500-5571033262Wix
Headlight SocketN/A separately from Yanmar826-84312-00Yamaha (used on snowmobiles)
Headlight Bulb194262-53080A7023LED bulbs available (search for "P15D-3 LED")
Turn Signal Light(multiple part numbers)TC222-33610Kubota part
Belt124060-44290A27Generic
Muffler(multiple part numbers)YM-1
CH15910
Stanley (generic Yanmar replacement)
John Deere (compact)
Battery Hold Down194262-51350AM101500Deere part. Use with 8" J-bolt hold down kit available at any auto parts store.
Fuse Box194200-5221015600-06-20Bussmann. Available at most auto parts stores.
My YM135 was missing its alternator when I bought it. The YM135/YM155 came with either a 3-wire regulator or a 4-wire regulator. Both types had two wires coming out of the alternator. The difference between the two is that the 3-wire setup had the rectifier (diodes) built onto the back of the alternator, while the 4-wire setup had the rectifier (diodes) built into the regulator.
Rather than trying to source a (rare and expensive) "3-wire" alternator, I decided to convert my tractor over to a "4-wire" alternator. I picked up a brand-new alternator on Amazon for $73. Also, I made the decision to go with a 6-wire regulator - because they are plentiful and cheap. To make this work, I ran two new wires from the regulator to the alternator. These wires connect the two leads coming out of the alternator to the blue leads on the regulator (polarity doesn't matter on these). I also ran three new wires from the regulator to the starter (battery), ignition switch, and ground. This setup requires a good ground! I didn't use the indicator light wire on the regulator.
The 6-wire regulator bolts right up under the dash, using the original holes. If you want to use the 6-way plug on the regulator, search Ebay for a Kawasaki or Honda regulator pigtail.
This converts the YM135/YM155 over to the same system that the Deere 650 uses.
   / Yanmar YM135/YM155 Parts Cross-Reference #3
Be very careful with a wix oil filter for gas engines on a diesel engine. The wix filters go below 32-micron and will reduce the oil flow. 32-micros should be the lowest and no more than 36-microns. A Purolator diesel engine oil filter would be your best bet.
   / Yanmar YM135/YM155 Parts Cross-Reference #4
  • YANMAR YM135 YM155 Parts Catalog.pdf
  • YANMAR YM135 YM155 Service Manual.pdf
   / Yanmar YM135/YM155 Parts Cross-Reference #5
The Yanmar turn signal light in your chart is the John Deere Amber Warning Light for each fender. These are the Steiner brand of OE lights. p/n ABC544
https://www.steinertractor.com/ABC544-Round-Fender-And-Cab-Mount-Warning-Light
$17. But, at Rural King and Farm & Fleet, the prices are under $15 for the Steiner brand lights.
They also make a modern LED version, but the price is just crazy.
Steiner also makes the OE rear flood work light too.
https://www.steinertractor.com/IHS3018-Rear-12-Volt-Combo-Tail-Light-with-Rubber-Bezel-Hobbs-Style-
Notice the mounting stem is angled. Depending on the Yanmar curved fender, this style will work best shining rearward. This once was sold in JD green and Massey red at one time too. Now, it's just Ford Boomer gray.
   / Yanmar YM135/YM155 Parts Cross-Reference #6
BTW, good luck in finding the headlight bulb for the A7023 P15D-3. The original for Honda and Yamaha machines were 25W/35W. Lowbeam/Highbeam. These are nearly nonresistant anymore. I no longer could find them at Napa. They were the last place that had them.
The Honda ATVs used them years back.
So, after digging I had found there is a 45W/45W version that is more popular, the 12080 P15D-3.
CANDLEPOWER 12V 45/45W H/L BEAM HEADLIGHT LAMP BULB J-BASE A7028 6245J P15D-3 12080
This would be brighter than any of the other Yanmar parts places like Hoye or Fredricks and are a direct fit. The LED version is 40W on the web.
Now, the P15D-3 was replaced by the H6M bulbs for motorcycles. The EU uses a boat load of these. The downside is, the glass bulb length is not a single length. It comes in a stubby and a tall length. These range from 25W, 30W, 45W, 60W, and 90W. On vehicles, 65W are highbeams.
As the EU went H6M as a replacement, Asia motorcycle makers went with the T19 bulb for the motor-scooters. However, the brightness power was 25W/35W, just like our tractors were from the 80s.
If I had to replace the bulbs, the A7028 45W 12080 would be a good pick. Then the H6M 45W as a second pick. LED prices are a bit too high at this time.
There's got to be more to oil filters than the micron ratings. The filter number specified above came directly from Wix's own application lookup. It has a micron level of 21, and a flow rate of 9-11 GPM. When I look up a filter for a John Deere 330 (3-cyl Yanmar diesel), it's the same story - 21 microns, and 9-11 GPM. Since Wix is arguably the most reputable company in the filtration business, I'd be surprised if they offered a filter *specifically for the Yanmar YM135* that didn't meet the correct specs.
I'll have to see if I can get my YM135/YM155/YM240/YM330 Electrical Service Manual scanned. I've never seen another one like it on the Internet...
The A7023 25W bulb is still available on the Internet from "2 Fast Moto". Of course, all of the "gray tractor parts suppliers" still carry them, too (they seem to only stock the gold-plated ones, though).
While upgrading to a 45W bulb would throw more light, that worries me. First, that extra light comes with extra heat. Will the 40+ year old bulb socket that was designed for 25W be able to withstand that extra heat? Second, the YM135/YM155 alternator was rated for 8.5A @ 14V (119W). The tail lights were designed for 20W bulbs. The headlights were designed for 25W bulbs. That's 90W in total. With 45W headlights, the tractor will actually consume more power from the battery than it produces.
When I originally purchased the LED headlight bulbs for my YM135, the only place I could find them was Aliexpress (they took 6 weeks to arrive). Now, a pair of bulbs is available on Amazon or Ebay for $13. The LED bulbs seem to be between 18W-22W.
For my tail lights, I ordered the reproductions (FL-4440). I tried the commonly available 4" lights (I think mine were Peterson branded - Optronics makes one too), but I felt that they just didn't look right on such a small tractor. The originals were roughly 2-1/4" in diameter. The reproduction ones have a plastic body, while the originals had a metal body. The number I provided in the table above should cause Google to display some square lights that look almost identical to the reproductions with the exception of being square, instead of round). If I get around to restoring this tractor, I might see how a set of 3" chrome-bodied lights look on it (Double Face Pedestal Archives - Grand General - Auto Parts Accessories Manufacturer and DistributorGrand General Auto Parts Accessories Manufacturer and Distributor)!
   / Yanmar YM135/YM155 Parts Cross-Reference #10
Still not the original Yanmar bulb that is low/high beam. The A7023 is 25W/25W. I have the original intent bulbs in mine. The 10W makes a huge difference.
Yes, the automotive sockets from that era out of Japan and Taiwan for motorcycles worked up to 90W. Your issue is the wimpy alternator on the YM135/YM155. The larger YM series machines have 35A alternators. And I still think those are weak vs. having the 55A or 60A for that era. There are new VRs for our machines that can handle the higher alternator output. A thread here mentions how to do the upgrade. 336D Alternator Upgrade & Lights https://www.tractorbynet.com/forums/yanmar/229542-336d-alternator-upgrade-lights.html
I checked locally at autoparts stores, recreation stores, and even lawn tractor repair stores in my area. Only Napa had them for $2.00ea. I bought a box that had 4 remaining. Whew, I just fetched the box in the garage at 18F outside. The brand is CandlePower p/n 3968, 12VDC 35W/25W OE bulb, Honda Head Light. The box data of manufacture was 10/1992. I bought them in 2014!
Here a link to an important bulb chart for the older motorcycles from Asia.
Automotive And Motorcycle Bulb List - Candlepower
For my tail lights, I ordered the reproductions (FL-4440). I tried the commonly available 4" lights (I think mine were Peterson branded - Optronics makes one too), but I felt that they just didn't look right on such a small tractor. The originals were roughly 2-1/4" in diameter. The reproduction ones have a plastic body, while the originals had a metal body. The number I provided in the table above should cause Google to display some square lights that look almost identical to the reproductions with the exception of being square, instead of round). If I get around to restoring this tractor, I might see how a set of 3" chrome-bodied lights look on it (Double Face Pedestal Archives - Grand General - Auto Parts Accessories Manufacturer and DistributorGrand General – Auto Parts Accessories Manufacturer and Distributor)!
Nice. The metal housings are a plus.
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
UNUSED CFG MX15RX EXCAVATOR (A51247)
UNUSED CFG MX15RX...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
