HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-28-2009, 08:16 PM   #1 (permalink)
Member
Default Stump Grinder Finished
I finally finished my stump grinder - - - and it actually works!
No major problems, no rebuilt.
One learning - - -position the tractor upwind when grinding!
Reggie
kruszert is offline   Reply With Quote
Old 06-28-2009, 08:35 PM   #2 (permalink)
Gold Member
daBear's Avatar
Default Re: Stump Grinder Finished
Wow is all I have to say. That looks great.
daBear is offline   Reply With Quote
Old 06-28-2009, 08:39 PM   #3 (permalink)
J_J
Super Member
J_J's Avatar
Looks good. Did you use a 1 to 1 ratio in the gearbox, or a step up ratio..
__________________
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to..
J_J is offline   Reply With Quote
Old 06-28-2009, 08:41 PM   #4 (permalink)
Skyco's Avatar
Very cool! Is it chain drive? How about the right angle gear box, what ratio is it? I'm also curious about the uneven spacing of the teeth on the grinder wheel.
Skyco is offline   Reply With Quote
Old 06-28-2009, 08:51 PM   #5 (permalink)
Gold Member
Big Bri's Avatar
As my kids would say "SWEET"
Big Bri is offline   Reply With Quote
Old 06-28-2009, 09:10 PM   #6 (permalink)
Piperflyer's Avatar
Could of used that 3 wks. ago. Nice job
__________________
'Life's Journey is not to arrive at the grave safely in a
well preserved body, but rather to skid in sideways, totally worn out, shouting, 'Holy S... What a Ride!!
Piperflyer is offline   Reply With Quote
Old 06-28-2009, 09:59 PM   #7 (permalink)
Gold Member
Me too! Maiden voyage yesterday! 20 some stumps! 4"-20" pine, some 6"-10" cherry. I'm happy with it! Poor pictures, better ones to follow! Hey-"DaBear"---I did it! ~Scotty
stump-grinder-finished-sgfinished1.jpg  stump-grinder-finished-sgfinisher2.jpg
Scotty370 is offline   Reply With Quote
Old 06-28-2009, 10:20 PM   #8 (permalink)
J_J
Super Member
J_J's Avatar
kruszert ,
Would you tell us a little more about the logic for the teeth placement.
__________________
J.J.
Old 06-29-2009, 09:43 AM   #9 (permalink)
Member
Scotty - - - looks like we finished about the same time. You are a few stumps ahead of me. Good job!
My gear box is a speed increase type. Ratio is 1 to 1.46. Bought it on ebay and it seems to work - - - never can tell about stuff from ebay. I used a
#100 roller chain and sped up a little more, 17 tooth on the drive and 11 tooth on the shaft. Running the tractor around 2100 rpm (2400 rpm is used to get 540 at PTO) works best. I have found that the grinder has a tendancy to pull into the stump if you are taking too big a bite. It can bring the tractor to an immediate stop - - a little scary. Just like any new piece of equipment I am learning as I go. No damage done so far - - - except for stumps.
As for tooth placement. I have 6 sets of angled Greenteeth (700 series)spaced evenly 60 degrees apart around the wheel. Then I have two sets of straight teeth 180 deg. apart. It shows in the picture and gives the impression of odd placement. I was told but the salesperson at Green Mfg. that the straight teeth were needed if I wanted to grind straight down into a stump rather than come from the side. I saw the same tooth placement on a Vermeer SG 252 so I figured I should do it too. Can't say that I have needed them but it was easy to drill a few more holes when the wheel was on the mill and would be difficult to drill later.
Thanks for kind words,
Reggie
Old 06-29-2009, 11:09 AM   #10 (permalink)
jenkinsph's Avatar
Very nice job there Reggie
Steve
jenkinsph is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 1.50795 seconds with 9 queries
