Also just a couple other things I've learned:
o-You definately don't want to build one as was mentioned with the wheel mounted at 90* to the tractor! You really need that tractor as a firm anchor point to 'hold tight' while your thowing chips out the back!
o-
You definately don't want one that brings the chips toward the tractor! I can't imagine the 'schrapnel' that would be 'greeting' the operator!
o- Your better off cutting a stump from the left side, (viewed from the drawbar, looking rearward). If you've set the bite/pass a little too deep, it will meet with 'rejection'! If you come in from the right, if will try to track across the top of the stump all the way 'til you stall, or it finishes a very 'scary/shuttering' pass!
o- On larger stumps, your want to line up to cut the first 1/3, (1/4?) closest to the tractor first. ie- using the 7-8 o'clock position on the wheel, when viewed from the right side of the unit. More learning in store for this weekend, along with the promised Pics! ~Scotty
PS One more point- Tractor placement is everything! Guess the downside to the 3PH Design! IE Cut part of a large stump, raise the unit, reposition, lower the unit set park brake, grind, remount, reposition, reset brake, grind etc, etc, I'm wondering if thats why some units are sold with 26-36" wheels! That would cut down on the multi-moves a bit! But, with mine, "it is, what it is" and I'm happy with it!
