How true! I was curious about requirements in our area and found some info for the county south of us. The Table of Contents shows what a property owner is up against. (I'm surprised there's no section regulating oxygen use of the air above your land.): :confused2:
I'd like to build a barn. Do I need a permit?
What projects need a building permit?
I want to build a tool shed, but a neighbor told me I need a permit to build it. Is that true?
What are the setback requirements?
Do I need a permit to clear vegetation from my property? What about next to my creek?
Can I cut down a tree or use a tree for firewood on my property?
Can you explain the notice I received from the Weed Board?
Can I outlet rainwater from the roof of my house, barn, or outbuilding directly to the ditch along the
county road by my property?
Can I deepen or work in an existing ditch on private property that may have silted in over the years?
I've heard that farmers don't need to get any permits. Is that true?
What kind of activities will trigger the need for a grading permit?
If I want to build a pond on my property, what do I need to know before I build one? What if I just like
the sound of running water, can I build a water feature?
Can I raise trout? How about other fish species?
Can I draw water from the small stream that flows on my property?
If I cannot use surface waters, what about using my well water?
What is an easement and how does it affect the use of my property?
What general advice would be good when looking at doing projects on my acreage?
http://clark.wsu.edu/horticulture/smallAcreageProgram/sm-ac-FAQ9-3-04.pdf
looking through the PDF file you linked to. what is needed for a permit and info that is stated. sounds fairly reasonable.
grading permit.... ya some folk up stream, may want to do a large redo of landscaping of yard. but 1/2 mile down stream. were all the water goes. along with any mud / water ends up. can be a completely different story. for folks that live right near were the stream enters the lake, were once lake was 20 feet deep is now only 5 feet deep within a couple years.
have you been out onto any major rivers? or looked into any streams. that water gets pretty nasty pretty fast, from erosion problems up stream and streams that feed into the rivers.
i hope you are not the person, i always think about. that has been sited multi times. for a gully washer errr ice glacier of cow manure, and pig manure, running from a live stock pen. down a hill a few hundred feet, into the ditch, and over the ditch, and then going down into the nearby stream, which has a few near by houses shortly down the stream. and be afraid any sort of spark that might happen. due to the gasses coming from the manure.
are you one them folks, that stocked there lakes with a fish, that got out of the overflow. and started wiping out a good portion of the local wild life? carp anyone? woops there went the kid off the boat, that just got hit by a carp that got spoked and jumped out of the water and hit the kid off the boat.
so you just pumped 20,000 gallons out of the nearby creak. to wash vehicles and everything else down, and you just did a big chemical treatment as well. so are you the person, that is responsible for the large fish kill down stream, with fish floating up filling the sides of the bank of the stream?
so are you the person. that just sucked out someones septic tank. and because you were out in middle of know were decided to dump the septic tank waste water into the near by field. were it just all ran down into the creak 50 feet away? and not a single thing actually was filtered out beyond leaving a film of nasty smell over everything.
errr, re-read post before posting it, and statements seem like they were directed to you personally lady tonka, but are just generic statements geared at everyone. and what many neighbors around here have went through, with a given person. i realize for many folks, many of them codes and regulations does not make sense, and ya just gotta scratch your head. and like huh? but when your the one receiving the ugly stick of someone elses doings. it is not so fun at all.
