Kubota M6060 vs. L6060 vs. NH T 4.75 vs. JD 5075E
   / Kubota M6060 vs. L6060 vs. NH T 4.75 vs. JD 5075E #31
You really need to work the tractor to appreciate it, you can't appreciate it driving around the dealers parking lot:)
True, I've posted many times that I was definitely underwhelmed by the HST+ on the dealer's lot and first week or two of operation, but came to really appreciate it over time. I believe other tractors are now coming out with some of the same features and they will become more common.
   / Kubota M6060 vs. L6060 vs. NH T 4.75 vs. JD 5075E #32
From what I can find, the ONLY advantage that Kubota's HST+ has over the competition is the 2 speed. All the other features-advantages that HST+ had over the other makes is gone. I have no doubt that once it is determined by the competition that the 2 speed is a big benefit, that they will soon follow with the same, just as they have with the other features. :cool:
Just my :2cents:
   / Kubota M6060 vs. L6060 vs. NH T 4.75 vs. JD 5075E #33
A synchronized shuttle would still require you to clutch to change directions. A hydraulic or power shuttle just requires a flip of a lever.
I think you've probably already thought of this, but you could afford three tractors if you keep the two you have and add a used ag machine. There's some real nice old IH rigs for under 12k around here. But they won't be the same as a new cabbed Kubota.
Another thing, with the power shuttle the clutch usually runs in oil which should translate to longer life, especially if you do a lot of reversing at row-ends, backing up with a mower, etc.
Just yesterday I was running a heavy field cultivator which would clog up occasionally with roots from killed mugwort that was plowed under. I found the best thing was to stop and back up a few feet with the machine in the ground to dislodge the roots it was dragging; same thing at row ends. I thought to myself a power reverser sure would be nice for this.
You mention using an old farm utility tractor as a 3rd machine. I noticed he has a 2520 CUT. If he had one of the full size 2520's manufactured up into the 1970's (or something similar like a White/Oliver with Over/Under or Ford/NH with Dual-Power) it could probably do all of the heavy work he's got now and still retain the JD hydro for less net $$ outlay.
   / Kubota M6060 vs. L6060 vs. NH T 4.75 vs. JD 5075E #34
Hey, it's good you're a tire dealer. Have you considered going to radials? They would give a lot more traction without needing as much ballast. That could keep your total weight down for transport concerns.
Actually boggen, I am a tire dealer. I did some research on available tires, tread patterns and ply ratings and have decided to go with either the Kubota M7060 or the John Deere 5075E. Both tractors offer 12X12 transmission options and can be ordered with R4 Industrial tires. I have found 10 ply fronts and 14 ply rears from Goodyear/Titan to switch out with the OE tires. Right now I'm in the pricing stage on both units. All things being equal, I think the Kubota would have a slight edge all around but it also carries a heftier list price. I think either tractor would get the job done for me so it will depend on which dealer is more aggressive in pricing. I believe I have my JD 4720 sold, so it may also come down to availability and who can get me a replacement tractor in the shortest time possible since I'm coming into one the my busiest times of the year...fall food plots. Last count I had right around 50 acres to get planted, so whatever I get will get a workout right out of the gate.
I appreciate all the input from everyone! I'll let you know what I end up with.
You guys may be onto an idea about the older ag tractor for the heavy work. My problem is that i'm not familiar enough with those older models to know what to look for on TractorHouse. Possibly, you could give me some ideas. Here's what I need...a tractor that can do heavy tillage, preferably 4X4, pull a grain drill and have a class I/II or straight class II 3 pt hitch that can lift at least 3300 lbs., AND be relatively easy to transport on a deck over, 12,000 lb trailer, with the attachment to be used. That means that tractor has to weigh in at no more than around 7500-8000 lbs. with ballast and/or weights. AND...have a loader that is relatively heavy duty. The loader won't go to the field so it's weight doesn't have to be factored in for trailering with implements. (We have a firewood business too and need a heavy loader to move logs in the fall and winter)
   / Kubota M6060 vs. L6060 vs. NH T 4.75 vs. JD 5075E #36
My 5325 would easily do everything you list AND it only weighs 6300(without my loader). I'd look for something like a 5 series tractor. 5010/5020/5025.
   / Kubota M6060 vs. L6060 vs. NH T 4.75 vs. JD 5075E #37
What kind of budget?
Good question...I suppose that it may take at least $10-$15K to get a usable machine. I could do that...maybe a little more. Actually, I think I have my 4720 sold already and I don't want to back out of the deal...the buyer has been very good to deal with. However, once it's closed and gone that means I could take the $50K+ I was going to spend on the new cab tractor and buy two used tractors...one hydro and one ag...probably both would have to be open station but I may be able to talk myself into that to get the versatility.
   / Kubota M6060 vs. L6060 vs. NH T 4.75 vs. JD 5075E #39
For $50K you should be able to find a couple of good used tractors. Here is a nice one for $32k. http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=8694645 With a bigger tractor would you need as large or as powerful of a compact tractor?
Geez Louise, that's a BIG tractor! Nice...but big. I've been searching for the JD5325 that Rolling Farms suggested and I found a couple nice ones. Not a bad weight at 6300 lbs...
To answer your question, no, with an ag tractor to do heavy work I wouldn't need the most powerful compact hydro...just something to mow, spray, run a spreader, 6' tiller. 40-50 Hp should do that.
2018 Chevrolet Silverado Pickup Truck, VIN # 1GC1KVEG4JF200556 (A36338)
2018 Chevrolet...
Agri Machinery Packing Line (A35780)
Agri Machinery...
2019 Dodge Ram 3500 Cab & Chassis, (A35430)
2019 Dodge Ram...
Tiny Home (A36337)
Tiny Home (A36337)
2006 Belshe T10 T/A Tagalong Equipment Trailer (A35915)
2006 Belshe T10...
28 Gauge Painted R Panels (A36337)
28 Gauge Painted R...
