Proud owner of a new owner's manual
   / Proud owner of a new owner's manual
Picked these up today.
$1300 total.
Like new both only used once.
   / Proud owner of a new owner's manual #42
I give up? What is the red thing Adam?
Sent from my iPad using TractorByNet
   / Proud owner of a new owner's manual #43
Side link, only after I get some splitters.
Adam;
If you get a hydraulic side link, move the adjustable side link over to left side. This will give you a lot of adjustability.
What does the check valve do for you on your upper link?
Arena groomer. I'm also going to see how it works on the driveway.
Adam;
From what I've read, it prevents it from moving when you set it. Since we don't have a float function that's why I choose this one.
   / Proud owner of a new owner's manual #47
Yep, I wish one of my rear remotes had float. I may see if I can add a check valve to my hydraulic side link.
FWIW, I have been pressing LS, thru my dealer, to complete their 3rd remote kit for the XR4046HC. LS had been promising it for almost a year. I'll find the thread I started on that and update you. I need 3rd remote for angle adjust on my LandPride 96" rear blade. I adjust tilt with my hydraulic side link.
I realized that I did not post pics of when I cleaned up my front hoses.uploadfromtaptalk1458528463098.jpguploadfromtaptalk1458528472391.jpguploadfromtaptalk1458528478389.jpg
Bought the clamps off eBay as they had free shipping and got some longer metric bolts from the local farm supply.
I think in the future I will up the hose size to 1/2" to increase the flow.
   / Proud owner of a new owner's manual #49
Re: Added Hydro top link
I added a hydraulic top link to the girl tonight it took about an hour to Teflon seal, tighten all the fittings, and route the hoses.
I have not tested it out yet but so far it looks to work pretty good.
Just curious, what is the reason that you mounted the hydraulic top link backwards?
Better interface with the hoses. Otherwise I would have a loop that would either be pinched or to tight of a bend.
   / Proud owner of a new owner's manual #51
Ya, I have yet to completely win the hose routing & management war on my install too.
   / Proud owner of a new owner's manual #52
They work great for box blades and forks!
I got the hydraulic fluid and filters done.
The large drain plugs require a 30 mm.
I drained and replaced just shy of 10 gallons.
I was surprised how the drain plugs looked.
Rear plug
Yes there are 2 distinct shavings on that magnet.
Front plug
The front axle I used a crescent wrench and replaced the Teflon tape on the fill and drain plugs.
It was a real pain in the butt to refill it.
I only cycled the hydraulics to purge them, I did not get to drive it around to see how the Kubota fluid works.
   / Proud owner of a new owner's manual #54
There should not have been any Teflon tape on that straight thread, the copper gasket provides the seal.
Only tighten enough that it doesn't leak
The axle only uses pipe treaded plugs with a square head.
   / Proud owner of a new owner's manual #56
Very nice work Adam and thanks for sharing all your detail!
I always wanted pallet forks but good gosh these things are a must have, top of the list first thing type of attachment!!
It just sucks that I only bought them because were moving in the next 2 months to Germany and I needed a way to load my 40x60 shop into a semi trailer for storage.
So sadly I will be selling the XR4046HC to some lucky guy/gal
When we come back in 2-5 years I will be buying a new one by then I think the very few items that LS is missing (RPM matching) will be addressed.
   / Proud owner of a new owner's manual #58
Well that sucks! Bought an LS cab tractor with cab... Then QA forks, now selling to move overseas. I'm sure a pay raise is in order to buy a bigger LS next time... LOL. Safe moving!
CT
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
