s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,608
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
It's not so much the weight of the tractor, it's the tires and the tire size/footprint. A good quick way to judge two tractors of any weight with similar tires would be to compare the tire pressure -- whichever has lower PSI will leave less impact on the ground (this is true of any vehicles). If the tires are loaded, then you will want to factor that in separately (there is a way to calculate it).
Anyhow, that's a long way to say that you can go with larger tractors and not necessarily damage the lawn more -- just get turfs if that is important, and remember to keep it in 2WD whenever possible. Something like a 2520 or B2620 with turf tires would definitely be OK on a lawn if you were sensible.
