Orange 08
Bronze Member
JJZ 109,
Where did you get your Fleetguard Precharged?
JJZ 109,
Earlier in the thread, Nalcool was mentioned as an additive. Without reigniting the debate, would this be a good choice regardless of the opinions about other additives? If so, where would you get it?
Tractor Supply carries it. But it doesn't come cheap. It was $15.99 a gallon.
I guess that I was mistaken about the name. It's Fleet Charge.
Not sure about your '99 Powerstroke, but I've seen it recommended at Dieselstop for my '97 to also use distilled water when refilling after a flush. Apparently this eliminates the mineral content and other things found in tap water.
Fleet Charge Fleet Charge Antifreeze, 1 gal. - 8000177 | Tractor Supply Company
But if a Kubota does not need it, why use it? His 99 or our 97 powerchoke (diff displacement) also has wetliners and does need it. Some Kubota's do and most do not.
Is dieselstop the same owner as the old Forddiesel.com? Owner is a %%^&*.
