Stradbash
JT
It goes out horizontally, toward the driver's side rear tire. Approach from the rear of the tractor.
That is the location of the strainer. As Mentioned by another, there is a "keeper" or clamp plate that holds the strainer in place. The bolt that holds that is 12mm. What I did to help coax the strainer out is to use a large screwdriver. Working from the back of the tractor with the screwdriver pointed toward the front I put one side of the blade in the slot for the clamp, after removing the clamp and bolt, and the other on the machined area where the clamp bolt was and twisted. It came out with very little persuasion... I probably had something between the screwdriver and the machined part of the tranny case against which I was prying, but it was a while ago...
