BossTractor
Bronze Member
Hi,
We run Alamo HD flails and have very little issues with them. The bearing issues we did have subsided when we went to the 100lb Timken-rated TRC 880 C&C grease. The Montage Alamo copy mowers did not work well and the 150 miles of Bush Hog mowing I did with the twin spindle Alamo RH-96 was a 2400lb maintenance nightmare. Can you believe we have super luck with the single spindle Deere HX-7? We use it to chop everything we grind with the skid steer and forestry head and we also use it in the field along side the flails because it does that good a job on grass? One broken blade a year verses about 30 Alamo blades.
At home I have a New Holland 918L/Maletti and it too has been a nice mower. Envy of the neighborhood when I feel like doing lawn striping.
On a side note we bought a new Deere 331G with tracks and Deere forestry head. Very little trouble in 50 miles of grinding 8 hours/day and the Yanmar diesel starts so good when it is below zero at the jobsite. Counting our blessings the Powertech is not under the hood.
We sent two 85P Mahindra tractors to auction and the other two are going soon. You would never complain about Deere or another color after 40 hours of steep roadside mowing in "the penalty box." A/C down almost every week of the summer. Just awful.
Personally I like the look, feel and quality of the T4.75 NH and its ALO factory loader. Sweet ride for sure.
Brian
Can you give me some insight into how well flail mowers hold up to abuse? I mow a lot of overgrown pasture land, farm yards, undeveloped lots, and a few oil leases. Mostly 2-5' tall grass, and thick weeds like Canadian thistle, tansy and small sapling up to a 1".
You find a lot of forgot objects when mowing. Steel pipes, chainlink fence, barbed wire, ground stakes, silt fence, rocks. Just to name a few things I've found and bashed blades of my rc2060 off of or wrapped around the pan and blades. Only damage i did was bent a blade once off a steel pipe. $150 for a new set.
How to the rear rollers hold up? I'm nervous it could catch on a small stump or metal ground rod and not jump over it and bend it.
