grsthegreat
Super Star Member
ya, the new tractor has a switch by the emergency blinkers that engages the 4x4. so its electrical/hydraulic engaged. wouldnt think it would matter
WRONG......You must be completely stopped and you must depress the clutch when shifting from 2 to 4 wheel drive and from 4 to 2 wheel drive. You might be referring to the differential lock in which case clutch does not have to be used nor does tractor have to be stopped.
From the Manual:
I have a gear tractor and engage/disengage 4WD on the go, without the clutch all the time.But on a gear tractor, You DONT neet to press the clutch and you DONT need to be stopped. Same as a typical 4wd truck. going from 4hi to 2hi and vice versa.
Sorry, but depressing the clutch is not necessary. The front drive train is moving at the same speed as the rear so engaging while rolling is only putting power to already rotating gears, not engaging any stationary gears. No clutch required. However, if the drive train is tight due to lots of turning and moving, depressing the clutch can help the disengage process. I actually just roll back a few feet to help release the binding torque and never use the clutch.
Maybe the question should be, "should" you use the clutch or do you "have" to use the clutch.
On my L5030, I only use the clutch to start it and not to change ranges or engage/disengage 4WD. Should I, maybe; do I have to, no.
I guess you're right and all the Kubota engineers and the Kubota manual is wrong then.................and lets not forget that the L3400 if actually front wheel assist with a slight lead on the front wheels over the rear wheels. There's a reason they give you a manual when you purchase a tractor.
