Jtullis13
Platinum Member
Ok guys I have my PS install done and working like I want it to. I am sorry a head of time, I forgot to take a few pictures as I went a long but will do my best to describe what I did, or what happened. Tools you will need, 10mm wrench and short socket, 17mm, 19mm wrench, 3/4" wrench or socket, large crescent wrench, pipe dope, hand grinder if you use the long oil filters.
PS kit from Fredricks/Hoye
PS cylinder mounting bracket that goes over loader bracket on the left side of the frame
Bracket installed on frame
Do not forget the black spacer that slides over the large bolt at the rear of the bracket, it holds the PS cylinder up to avoid hitting the bracket
The bolts that hold the bracket to the frame are 3/4"
the 3rd bolt that goes to the transmission and block in this picture is 17mm
The factory drag link or steering link nuts with cotter key are 17mm sorry forgot to take a picture of that. The replacement nut in the kit is 19mm.
PS cylinder installed before modification to square housing
that square block does not work with long oil filters I almost punched a hole in mine. I didn't want to switch to the short oil filters because I have 4 of the long ones already in my shop and its a pain to change the short oil filters.
Here is a pic after I ground down that block as you can see the wound on my oil filter before I smoothed that piece out
The hydraulic line closest to the oil filter is the return line which is the longer of the 2 hydraulic lines
The hydraulic line on the left is the pressure line that is run over the bell housing under the fuel tank. That line is connected to the CF port on the FCR51 flow valve shown here. If you notice I used straight fittings instead of the 90 degree ones they sent in the kit, I figured better flow. The CF fitting is a 3/8 x 3/8 The EX port is 3/8 x 1/2
the right side of that FCR51 flow valve is labeled "EX" I will explain that part later
The return line is suppose to dump into your hydraulic fill port between your gear shifters, I had other plans so I routed the PS cylinder dump to a port under my seat shown here
I used a crescent wrench to remove this plug, threads are M18
The fitting shown here is a M18x1/2 elbow that went down to 3/8 to fit hydraulic line shown here
And now installed
The FCR51 Flow valve is installed on right side of the tractors bell housing bolt 17mm
Ok so the instructions say to remove the round port that connects to your hydraulic pump to feed the FCR51 valve, the valve will supply oil to the PS cylinder from the CF port and the EX port will go to your loader. I tried this and didn't like it. The PS was ok, but nothing to brag about. The loader was slow but still had lift capabilities. I decided to re-route the hydraulic lines. I left the pump feed the loader here, line from pump
to the loader valve which is line coming into the loader valve from the bottom
The line from the top of the loader valve is my Power Beyond port (PB) the line feeds the FCR51 valve from the IN port on the bottom, I also used a 45 degree elbow for better flow, I know that small applications like this it probably doesn't matter that much, but since our factor pumps only put out about 6 to 7 gpm I figured anything to make it easier to flow is a plus
The FCR51 CF port feeds the PS and the EX port now feeds the 3pt instead of going to the sump, this way the PS gets as much flow as I want to make it work really smooth and easy. pic here showing the EX to the 3pt
So back to diagram. The Pump feeds the loader valve (Koyker loader 120 is a Dinoil valve) the PB power beyond feeds the FCR51, the FCR51 CR port feeds PS, PS outflow to sump under my seat, FCR51 EX port feeds 3pt, loader valve outflow to sump between the shifters with supplied fitting in the kit which was suppose to be original sump port for PS outflow shown here.
that line is run under the dash and fuel tank out the right side to the loader outflow valve. The loader works great, smooth and fast, the PS works smooth and easy, the 3pt works slower but is able to raise my 5ft yanmar tiller, so I'm happy, my shoulder is happy, all is well. Just one catch, when using the loader the PS cuts out, I don't lose all PS function but most of it, I can still turn the wheel as before, just acts like it back to original steering is all, so I can deal with that. I can learn to lift before I turn ect. Hope everyone likes this and hope it is easy to follow. With the added parts, Hydraulic line for PB port, PB port, and extra fittings I spent an extra $65, but well worth it to me. More pics
[[URL=http://s1378.photobucket.com/user/JimBeamLover/media/2210d/IMG_1361_zpsa0pfeizf.jpg.html]]http://i1378.photobucket.com/albums/ah114/JimBeamLover/2210d/IMG_1362_zps8no00hfh.jpg[/IMG][/URL]
And now installed
