Snakebit12
Hi all,
Looking for some advice.
Have a 7' Diamond Hydraulic front-end blade quick-connected to my Kubota 7040 for plowing snow and two font-end hydraulic remotes. The blade is heavy - 900 lbs - and has two mushroom skids (maybe 6" diameter). I have read posts on here about how to use these things and have seen the recommendations to put the blade in "float". On my M7040, you set in float by pushing the joystick all the way forward and locked.
Tried that today and dug up about 3" of gravel. So, with a big snow coming overnight, I am resigned to using my old method - trying to keep the blade fixed a few inches above the gravel - someone called that the bulldozer method. That process isn't easy given that there is literally no 5' section of my 3/4 mile long driveway that is flat. I am constantly rasing/lowering the blade depending on whether I am going uphill or downhill.
Is there a chance that the "float" isn't working? That blade sure as **** did not float on top of the driveway (fairly well-packed crush and run). Can the downward pressure on float be adjusted?
I have alot of rock rake work to do this spring.
Bummed in Virgina
Bummed in Virgina
