wdchyd
Elite Member
I pour my used motor oil on my sandy road. Helps settle the sand and control dust
:confused2::confused2::confused2::confused2:................:thumbdown:
Why use 15W40 when its twice as much?:confused2: Around here the cheapest 15W40 oil I can get, (Rotella, Dello 400, or Mobil Delvac) runs $12 per gallon. I can buy bar oil all day long at Menards or Rural King for $5.99 per gallon.
Chris
I would not put used motor oil in a chain saw. My FIL did this for a couple seasons and then the pump stopped drawing oil. I took the saw apart and found the lube oil hose was like goo, I assume from the contaminates in the used oil. I have burned some in my house oil furnace. I filtered and mixed it with normal fuel with no issues. The furnace filter and blower nozzle get replaced fairly often as maintenance and haven't seen any issues. Actually, I'm way overdue to replace them as it is and it's still fine.
Another option is to buy a bypass filter system and stop changing oil altogether! You would still change filters and have the oil tested at intervals (long intervals) but as long as the oil is clean (bypass filter system) and the additives don't wear out then there is no reason to change it. There is a company on the gulf coast that had one of their bypass systems on a 1990 Peterbilt that went 1 million miles with 1 oil change and the only wear was in the rings. And he only changed oil because it was dumped by mistake at the 500,000 mile tear down. He is now near 1.5 million miles with only rings replaced and the oil is near a million.
If i buy chain oil in 1 gal cans and we get 15/40 in 205 litre barrels they run about the same per gallon the benefit is convenience of just running to the barrel to get it . Even Wal-mart is more like $10 a gallon for chain oil !
