buickanddeere
Super Member
Bigger is better with tractor sizes.
Hello all,
I wanted something kind of like the Kubota 2601 TLB, or maybe Kioti CK2510, LS, etc, but I live at 9,000 feet and some math quickly figures up a naturally aspirated 25hp engine becomes more like 18ish.
I want a turbo because much like my Ecoboost truck they will be relatively unaffected at this altitude. But I am having trouble finding anything under around 40hp that is turbod, and I'd really rather not have a bigger 40 hp tractor if I don't need one.
What all is turbocharged out there, or should I just buy a mid 30s horsepower tractor and use it as a 25 hp tractor?
Thanks!
You are right. We live at 7000 feet and all of our diesel equipment is turboed. It's not just the altitude, but it's that in the mountains you tend to find yourself on slopes and side hills. Basically, for all your machines you need to recalibrate yourself into looking at least one size larger than you did in Alabama. In the Rockies, you have rocks and snow. Driving through fresh snow is like always driving uphill. Snow has decent traction if you have enough weight to compact it.
Our go-to machine is our M59 Kubota TLB. It has the weight, power, and turbo necessary to get around all year without chains. Plus accessory hydraulics and cat II 3 pt. Don't know if the smallest TLBs are turbos; I had thought that the larger Kubota TLBs were all turbos even though the literature doesn't mention it anymore. Anyone? IMHO, that Kubota 2601 is just too small for a small farm at 9000 feet in the snow.
luck,
rScotty
luck,
rScotty
I agree with this^^^^
I would rather have more ground clearance in the snow too. 110tlbs are not turbo charged either and I do notice a difference when working at higher elevations in NM. My 4520 is and does very well at 10,000 feet with no problem.
I'm glad you mentioned the ground clearance in the snow. Ground clearance really helps getting around in a mountains if the winter is snowy. This last winter was not typical. In fact, we hardly had winter at all this year.
So it's worth looking for decent ground clearance and a wider stance to deal with slopes. Any weight down low or wider tire stance helps stability too.
And I agree with Moluke on those Masseys. Nice tractors, decent dealer network, and worth a look. The one I tried was very comfortable to operate. Branson isn't the only other option.
The M59 is probably my tenth tractor but my first HST, and I'm now a believer. For loader work, HST is just better in every way. But it's worth mentioning that's on a tractor with turbo and 60 hp, and the 3 speed hydrostatic is the high end type with High and Low on each speed as well as on reverse. All that extra gearing helps compensate for the lost power.
good luck with the search. The only way you will really know is to get something and try it for a season. Any tractor is better than none.
rScotty
