BCS Model 715 tiller?
   / BCS Model 715 tiller? #1
Ezzrider
Kubota B7510
I am in the market to purchase a used rear tine tiller. I have seen a BCS Model 715 with a 8 hp engine advertised for sale at $600 locally. Anyone know about the BCS tillers and does this sound like a reasonable price? Supposedly it works fine.
   / BCS Model 715 tiller? #2
If it is in good shape and runs well, I'd think it's worth it. Make very good tillers. Had a 715 with a 20" tiller myself.
Thanks. I have not actually looked at the tiller yet. It is supposed to be in good shape but who knows. I like what I read about the BCS tillers. I had not heard of them until I saw this ad.
   / BCS Model 715 tiller? #4
Make sure you check the oil in the tiller gearbox, stuff wrapping around the shafts can ruin the seals. The gearbox seems to be almost indestructible, but must have oil in it. Seals are not expensive, but a little difficult to replace. There is a good how to here on doing it.
Make sure the transmission has oil in it too.
Check the tines, if they are wore down to a point they need replaced.
If it is good shape it is probably sold. I spend 6 months tracking one down.
   / BCS Model 715 tiller? #5
$600 sounds like a great deal. I paid that for my 730 w/Tiller about 8 years ago.
If it is in good shape you won't be disappointed with a BCS..Also there are a bunch of attachments out there for them.
Thanks for the input.
I bought it today. The owner told me he was the second owner with the original being a farmer down the road. Everything looked ok except the tires had pretty good dry rot but are still servicable. I/we could not find how to check the transmission oil. The owner told me he had not been able to find where to check it and I could not find a place either and he had no book on the tiller. There is a cap on top of the transmission area that looks like a vent cap. Nothing was leaking and I saw no signs of previous leaks. The tiller cranked right up and the transmission engaged in all gears forward and reverse. He tilled up a small area and the tines worked fine. The tines looked ok with no broken or worn down tines. When the tiller first starts up it runs on a high rev for a bit and then slows down. He said that it had always done that. Is that normal. I am hoping I did not get screwed on this but everything seems to work. It has some minor rust but overall looks good.
   / BCS Model 715 tiller? #8
In addition to the tractors transmission oil, you need to check the oil in the tiller. You have to remove the tiller hood and there is a plug on top of the gear box.
Not sure about the high rpm at first, other here are familiar with that engine. Many speak highly of it.
Don't forget you can get other implements for this tractor. It is more than just a great tiller.
Thanks. I will look for the tiller oil plug. I still cannot find the transmission plug to check that.
   / BCS Model 715 tiller? #10
Here is a pic(with circles and arrows) of the dipstick. As per my other post, put it back in with the flat side towards the center of the transmission.
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
DEUTZ MARATHON...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56436)
2023 Kubota Z412KW...
