Yanmar 2_31 4.70 star(s) (7)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Yanmar 2_31.
Under 25 HP Tractors
About the Yanmar 2_31
Yanmar 2_31 Discussions (46)
Here are the most recent 2_31 topics from our community.
  1. TNhobbyfarmer
    Yanmar 2000
    I recently posted about a Yanmar 1500 on Craigslist that I intended to look at. It sold before I had a chance to look at it. I am now looking at two other Yanmars on Craigslist, a F195 4wd with...
  2. dos0711
    Yanmar 2000 and a subsoiler
    I'm thinking about trenching a line to my shed that's about 300 feet from available power. My question is can the Yanmar 2000 2wd handle a subsoiler? Is it a waste of time and money? Thanks!
  3. R
    Yanmar 2000 as parts tractor for a 1700?
    My first post - be gentle :) I've got a YM1700 I really like, plan to keep it forever. Locally is a YM2000 for sale with a "bad engine" (nope, don't know more than that). I was thinking of...
  4. S
    Yanmar 2000 brake parts
    Does anyone have a good source for old Yanmar tractor parts (other than Hxxx). I inherited a Model 2000 2wd Yanmar (green) that has just the housing on the RH side, but nothing else. No bolts...
  5. dos0711
    My Yanmar 2000
    I saw this Yanmar on craigslist and it looked like it would fit my needs. I just bought 5 acres and will need to do some clearing. Nothing major mostly brush. Anyway, Probably paid way too much...
  6. J
    yanmar 2000
    How in the universe do you remove the rear hub? Please any info is more than i have...and yes i have tried several different pullers....nothing fits...??????
  7. D
    Price Check Yanmar 2000
    I have owned my Yanmar 2000 for about eight years. I live in Tullahoma Tennessee very close to the large but now closed used Yanmar dealer, Tullahoma tractor. I looked for a long time and bought...
  8. turnerbend
    Yanmar 2000 tractor
    Thinking about getting a 2000 Yanmar tractor. I now have a Yanmar 1500 that I've had for over 10 years with very little problems. I need a few more HP and I think that the 2000 will give me that...
  9. B
    yanmar 2000
    Has anyone had experience with VN Tractors. Inc.?
  10. B
    yanmar 2000
    I think I seen somewhere on this site if tractor starts and died and if there is water bubbling in radiator this means????
  11. B
    yanmar 2000
    How do I check the oil level if there is no actual dipstick? Just put enough in that I can see the oil? Thanks.
  12. F
    Yanmar 2000 will not start
    This is an older Yanmar I purchased that was not running. I added a fuel filter (the fuel tank was connected directly to the injector pump), replaced the started solenoid, rebuilt the starter...
  13. O
    Yanmar 2000 rear axle oil seal needed
    I disassembled my YM 2000 rear axle hub and found the leaking oil seal and the race that it rides on was worn badly. The Seal is a NOK AE3045E. I cannot find one anywhere and Hoye Tractor does...
  14. 1
    Oil & Fuel I have a Yanmar 2000 that i can't get transmission shifter cover correctly reinstall
    I can't get forks on my shifter assembly in right location...please help. It works in reverse tor a minute but that's it won't change gears and stalls out. Links, step by step, or illustration...
  15. D
    Torque Specs for Water Pump Yanmar 2000
    I'm trying to find torque specs for water pump for Yanmar 2000. I've searched through the forums and couldn't find this info, but I'm new so I could have missed it! :) Thanks in advance!
  16. D
    Yanmar 2000 puffing white smoke
    This a tractor that I bought a little while back just to mess around with been setting in a barn for a while, I had the injector pump rebuilt, it had one stuck plunger,, will crank right up now...
  17. swmillbrook
    yanmar 2000 power assist
    does any one have knowledge on power assist on a yanmar 2000? it has a loader and we sold it to a customer. he brought it back due to some leaks on the hoses and we discovered the power steering...
  18. S
    Yanmar 2000 Steering shaft
    I put a brand new steering box on this tractor last summer (less than 15 hours ago). At the very end of my bushhogging today, hit a small stump while turning and POP- steering wheel went...
  19. T
    Yanmar 2000 hydraulic filter
    1. Where is the filter? 2. Does anyone have a part #? 3. Where can you order one?
  20. T
    Yanmar 2000 differential fluid
    Do the Yanmar 2000 differential, transmission, and 3 point lift all use the same fluid? What is that fluid: Hydraulic or 80 or 90 wt. oil?
[ad placeholder]
User Reviews (7)
Read what TractorByNet members think about the Yanmar 2_31 Subcompact Tractor
5
71 %
4
29 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
Anonymous Poster
2_31 Yanmar
Yanmar 2000
Model Year: 1977
I would recommend a Yanmar to anyone who asked. Mine was refurbished when I bought it 5 years ago, in 2009. I have put about 150 hours on it without any problems to date. It pulls a 4’ bush hog just fine. I’ve actually cut over 20 acres this year alone with it which is why I’m in the market for something bigger. I can cut a 9 acre pasture in 12 hours in 6th gear, just to give an example of how long it might take. I use a 55 gallon sprayer as well. With front weights, it carries the sprayer just fine. Without the weights, it will pick up the front tires when full. I also pull a 4.5’ disc. It does fine here as well but weights will definitely help. The tractor is a little small for the sprayer and the discs, but gets the job done. Everything else it does great with, 4’ tiller, 4’ bush hog, etc.
Pros: Durable, good torque, economical, simple, tough.
Cons: None.
5.00 star(s)
n66wxm
2_31 Yanmar
Owner Equipment
Model Year: 1976
Additional equipment: Box blade Landscape rake Tiller Auger Bush hog Finish Mower Lift pole Sub Soil ripper I also have a Case 1835 (propane powered) skid steer, front end loader. Used for: Landscaping and working a 1 acre garden on my 6 acre lot.
Pros: Economical to run.
Cons: Not 4 wheel drive.
5.00 star(s)
lott1057
2_31 Yanmar
Yanmar 2000
Model Year: 1979
This is a great little "baby" tractor. I got it mainly to bush hog. The Bush Hog, blade, and disk came with it and I have been pleased with all of them. I wish I had a front end loader on it. The only problem that I have had is overheating. I plan to get the radiator cleaned out this winter. I said it was a 1979 model, but to be honest i have no idea.
Pros: Reliable.
Cons: Lightweight.
Photo Uploads:
5.00 star(s)
fcmazz
2_31 Yanmar
Does the Job
Model Year: 0
Had this Yanmar for a couple of years. Left it out in the weather while I was deployed for 18 months and started right up after a little fuel filter cleaning. Would recommend for 1-5 acres ranch/farm place.
Pros: Reliable.
Cons: Could have bigger/wider front tires.
4.00 star(s)
cataulajcb
2_31 Yanmar
Yanmar 2000 Used
Model Year: 0
Tractor was purchased for cash individual sale so I can not rate reliability or dealer service. This is a grey market tractor with very low hours. I believe it has been serviced or overhauled at some point. I had a Ford 1300 which was under powered for me. The Yanmar has lots of power for a 5ft mower in tall fescue and is very easy to service. Routine maintenance parts are easy to get on the internet as are operator and other manuals. Buying a used tractor is always a risk but so far this has been very good. You MUST have an over running clutch if you use a mower. No ROPS and most safety features required on US tractors.
Pros: Simple well made.
Cons: No live PTO MUST! Have an over running clutch when using a mower.
4.00 star(s)
shawnk1
2_31 Yanmar
Yanmar YM2000
Model Year: 1979
The tractor itself has been dead reliable. It had just turned over on hours when I bought it roughly 10 years ago and I have put around 300 hours on it since. Engine/ transmission appear as if they will go a couple more decades with routine maintenance. Other than fluid changes-to date I've had to replace fuel bowl,air cleaner assembly, and the steering box. These things vibrate like crazy-watch for loose bolts. Outside of a nagging electrical/charging problem which has required me to jump the tractor off (sometimes a long drawn out process during the winter months), I have no complaints, and feel like the roughly 3,000 dollars I paid for the tractor were well spent. Dealer bailed on Yanmars about 18 months after purchase, so parts are an online deal for me.
Pros: Great value, tough little tractor.
Cons: Noisy; primitive compared to new compact tractors.
5.00 star(s)
capt1989
2_31 Yanmar
YM2000
Model Year: 1979
I can't say enough about this little tractor. It has had a hard life since I bought it. It has 160lb cement wheel weights on each wheel, and in the early summer I fill the rear tires 3/4 with water. It has a front end loader that is used to haul and push and everything in between. I also have a pond scoop, 4ft bush hog, 4ft box blade, and a boom pole. I over load the FEL bucket more often than not when using it, and if it (the tractor) broke tomorrow I could not complain. My wife let a relative use it while I was at work and he managed to break the front axle housing, which I welded up and have had no problem with since. I purchased a back hoe ( LW6 ) which was delivered to my house yesterday. I am going to mount it to the tractor with a subframe, it is to heavy for the 3 point on the little Yanmar. Should be an interesting experiment.
Pros: Tough as they come. Powerful. Easily underestimated.
Cons: Not enough weight, but I use it hard...while being careful.
[ad placeholder]
Yanmar 2_31 Owner Pages
View owner pages to see photos, customization and comments about member-owner Yanmar 2_31s
Yanmar 2_31 Community Rankings
#110 user rating of 731 Under 25 HP Tractors items
#165 Viewed of 731 Under 25 HP Tractors items
#56 discussed of 731 Under 25 HP Tractors items
#787 user rating of 19625 items overall
#1331 Viewed of 19625 items overall
#311 discussed of 19625 items overall
Highest Rated in This Category
    No results found.
