Ford 640_2 4.50 star(s) (13)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Ford 640_2.
Vintage Tractors
About the Ford 640_2
Ford 640_2 Discussions (36)
Here are the most recent 640_2 topics from our community.
  1. 5
    1955 Ford 640 hydraulic issue knocking
    Hello, recently my hydraulic lift was slow to respond, I finally got it to lift and encountered a loud knocking and rattling in the pump area. I pulled the pump and found play on the gear and...
  2. O
    trouble with distributor on my 1954 ford 640
    When I try to start i t distributor spins and knock the cap off . I am trying to time it so I do not have it tightened all the way.
  3. L
    Help my ford 640 12 volt generator system is not charging
    I have been working on this for a few days, I loosened the fan belt, connected a booster battery between the armature and field terminal and the generator turns, so the generator is OK. I just put...
  4. M
    ford 640 pto jammed
    my 640 has the pto jammed so it just messes when the clutch is out. not enough to engage, but i can hear it grind when the clutch is out. I have tried to move it in and out and cant make it budge...
  5. J
    1954 Ford 640 Hydraulic Question
    I have a 1954 Ford 640 where the lift arms drops immediately after the engine is cut off. Also during operation the load "bobs" up and down. Any thoughts, opinions or suggestions wlll be...
  6. C
    1857 Ford 640 Fuel line replacement
    1957 Ford 640 Fuel line replacement - has a NAA tank I've got a 57 ford 640 that I have been trying to bring back to life through the summer. I'm finally taking care of the fuel system and I'm...
  7. J
    Ford 640 front axle pivot pin question
    I'm working on renewing the bushings/bearings on the front of my 1955 Ford 640 but I have a question before I put it all back together. I've ordered a new bushing from Steiner tractor (ABC379) and...
  8. J
    Ford 640 Hydraulic Manifold Question
    Hi all, been snooping for a long time but this is my first post. Tried searching and haven't been able to come up with an answer so hopefully I didn't overlook something simple. I have a 1955...
  9. F
    Hydraulic issues Ford 640 with Ferguson loader
    Greetings all. I've been tinkering around with this Ford 600 series most of the winter. When I bought it, the hydraulic front loader worked pretty well. but then sporadically, it would not raise...
  10. G
    Ford 640 3pt.
    I have a Ford 640 tractor. It is about 18F out side the 3pt. hitch will not work. The tractor is keep in a unheated barn, i had the space heater (110,000 BTU) blowing on it for about 45 min form...
  11. S
    Help with 12 volt wiring on ford 640
    Been having problems with the battery going down on my 640 that I bought about a month ago. Previous owner done a 12 volt conversion. When I started tracking single wire from alternator back, I...
  12. C
    Ford 640 Crank pulley removal
    New to the forums. Search didn't give up an answer. Crank pulley rim separated from the hub portion the other day. I figured 1955 to 2014 it has had a good life. I have a new pulley to put on...
  13. N
    Solenoid Wiring for Ford 640 with 12v 1-Wire Conversion
    Last year I had to do some work on my tractor with it not starting and ultimately traced it down to the starter. However, I wanted to clean everything up in there as there were jumper wires going...
  14. A
    1957 ford 640 won't drive
    hello new to site . i broke my 640 tractor moving snow today, 1st gear just above idle drove in to snow pile moving loader up and POP now no drive forward or reverse every thing else works just...
  15. A
    help with ford 640 tractor
    well today wasn't a good day. i've been using my tractor for snow removal all winter with minimum problems and today it broke. i was using the front end loader ans 1st gear moving a pile of snow...
  16. N
    Ford 640 w/12v conversion - Started Then Wouldn't Start - Electrical
    First off, this is my first post and I want to say thank you for everyone being as helpful as they are. I would have needed to post a long time ago if it wasnt for the knowledge base that has...
  17. O
    drawbar for Ford 640
    I'm trying to mount a drawbar on the underside of my Ford 640. It seems like a pretty straightforward operation, but there is some kind of flange around the PTO shaft that is in the way. Has...
  18. R
    Ford 640 12 Volt Conversion Clean Up
    I bought this tractor well after the 12 Volt conversion was done to it. I was told the charging system worked but the Volt Meter wouldn't so I wasn't too concerned. I knew the 12V sealed beam...
  19. J
    1955 Ford 640 Distributor Mechanical Advance
    I ended up as the caretaker for a community owned tractor. She ran pretty good in the 800- 1700 RPM range but wouldn稚 idle lower and was balky at higher RPM痴. Today I put a timing light to her...
  20. M
    Two bottom plow. ford 640.
    the 2 bottom plow as been sittin for years. Its rust, but very solid. I have been told by an old timer that the plow will not work unless its cleaned up real nice. The tractor has wheel weights...
[ad placeholder]
User Reviews (13)
Read what TractorByNet members think about the Ford 640_2 Subcompact Tractor
5
62 %
4
31 %
3
8 %
2
0 %
1
0 %
5.00 star(s)
Grumps2
640_2 Ford
Ford 600
Model Year: 1957
Great little tractor.
Pros: A real work horse.
Cons: No power steering.
5.00 star(s)
Anonymous Poster
640_2 Ford
A Great Tractor
Model Year: 1957
It has done everything I have needed.
Pros: Very dependable.
3.00 star(s)
allen6634
640_2 Ford
Good Value
Model Year: 1955
I will admit that this was a good tractor in its day, but things where different in 1955, even that this evens runs is something to say about the quality. I will admit that there is better tractors on the market now, but for a very low cost I think this is the way to go.
Pros: Very low price.
Cons: No modern convinces.
4.00 star(s)
terrymunn
640_2 Ford
1956 Ford 600
Model Year: 1956
Haven't owned it long, but so far...great performance. Starts easily and this one doesn't burn oil. Replaced left rear tire tube. Installed the screw-on oil filter modification. Replaced the gasoline shut off valve under the tank. Cleaned, lubed, oiled everything. Everything works as advertised. Wishing it had a "live" PTO. Finish mowing is okay but the cultivator work is slow going.
Pros: Inexpensive, reliable, parts easily found, many still in service.
Cons: Lacks live PTO, limited horsepower (23).
Photo Uploads:
5.00 star(s)
Anonymous Poster
640_2 Ford
Ford 640
Model Year: 1955
My 640 is a rock solid, great running reliable machine. I looked extensively for this particular model as it is the make and model I first learned on as a kid over 30 years ago. I use it with a Ford 907 series Flail mower and a box blade as well.
Pros: Great runner, plenty of power, very dependable.
Cons: The usual maintenance an older machine requires.
4.00 star(s)
mpendray
640_2 Ford
1956 Ford 600
Model Year: 1956
I bought this tractor from my neighbor last year. The only problem that I have had was me not turning the key off when it stalled. This caused the condenser to get fried. It has a old rear snowthrower which is a blast to operate if the snow is not wet. I ended up using the back blade for the second half of the winter. We have 3 acres and I plowed & tilled it with attachments. Got a dirt digging attachment which is great for moving & dumping dirt & gravel. This summer I bought a 6 ft finish mower for it and it does a great job.
Pros: Reliable.
Cons: None.
Photo Uploads:
5.00 star(s)
Sno
640_2 Ford
Excellent Value
Model Year: 1955
It was very used when I bought it and pivot points that had no grease fittings on FEL and backhoe were very loose. The ones with grease fittings were better but still worn. Tach hadn't worked for at least the prior owner and looked like it may have been at 3700 hours when smashed. It leaked engine oil badly but ran okay. I fixed rear seal on motor, put in new tach, and replaced broken zerks and installed an engine heater. It sits outside, but does get regular oil changes and greasing. It has over 1000 hrs on new tach. It has been worked very hard moving rock, gravel, wood, and snow. It looks terrible and works well. It doesn't appear any more worn out now than when I got it.
Pros: Lots of hard work done at minimal expense.
Cons: Looks terrible. Hard to work in tight spots.
4.00 star(s)
singleken45
640_2 Ford
I've Been Disabled Since 2000, Then in 2011 Classed as Retired
Model Year: 1956
I had traded my tired 9n in on a 1956 640 to upgrade to more power & better hydraulics. It needed much TLC at the time. Had the steering box repair, & a Sherman Hi/Lo installed at the same time. Then I did all tin repairs/replacements, plus new paint . In 2001 I found & bought a badly deteriated 1952 8n Funk conversion. Hauled it home & started tear down & evaluations. First on agenda was tearing the engine down, then taking it to a machine shop for evaluation & machining. Picked up newly machined (.060) block , head, & everything else at machine shop. Started locating parts & ordering immediately. $2,500.00 later, I had the engine completely rebuilt & ready for install. Next I installed a Sherman Hi/Lo ahead of the original 4 spd. After completeing hyd. oil removal & cleaning out transmission & rear end, the all new hydr oil install, found a large crack in bottom of 4 spd trans. Located a clean empty trans case , so I did a complete 4 spd RR. Next I installed my newly acquired Everett transmission. I then found & acquired but still have to install a Howard gear reduction trans. After all that extra work & newly rebuilt engine install, I had my engine running smooth as a kitten purring. Now being broke, I have to wait for some new cash to come in so I can get back to completing my full rebuild. When finished, I hope to own the only 1952 8n Funk conversion with 6 cyl OHV with 4 transmissions. Man I sure can't wait to be able to show pictures. God bless.
Pros: Enjoying.
Cons: Unknown.
5.00 star(s)
MGBBob80
640_2 Ford
Great Tractor!
Model Year: 1955
I love this tractor. It runs like a champ, does everything I want and is simple to maintain. This model has a 134 cubic inch "Red Tiger" engine that pumps out 31 HP. She has a four-speed transmission with the Sherman over/under option that gives it 12 forward gears and 3 reverse. PTO and hydraulics complete the package.
Pros: Easy to work on with basic hand-tools.
Cons: Local dealer is pricey and so must rely on the Internet for parts.
Photo Uploads:
5.00 star(s)
michaelpoe260
640_2 Ford
Ford 640
Model Year: 1957
A simple American that's easy to work on, plenty of power for chores around here. Built when a small handful of SAE wrenches could fix anything on the tractor. Parts are still easy to acquire and lots of technical help available. Some of the members of this forum have always had good info and suggestions to keep the Ford going when I would get a little stumped as I was rebuilding all the components. The tractor is all original and has been rejuvenated after being totally submerged in the Brazos River for several days. A real little workhorse for light to medium type work, cheap to operate.
Pros: Reliable, cost of operating, simple design, parts, American made.
Cons: Manual Steering, Mechanical PTO makes overide clutch a necessity.
5.00 star(s)
Mike Hamrick
640_2 Ford
The Worlds Greatest Tractor: Ford Jubilee
Model Year: 1956
I work a Jubilee almost every day. Sure it does not have power steering or a fancy transmission. But it does one thing very well. It runs reliably every day. I don't have to fix it to use it. Everything works the first time. Its strong as all get out and does everything I ask of it. From planting corn to digging a pond, my Jubliee will get it done. Sure shes not the prettiest in the show but she'll still be running when the rest of them are in the shop.
Pros: She's been paid for for 56 years!
Cons: Can't think of any.
5.00 star(s)
butchwester
640_2 Ford
New Old Tractor
Model Year: 1955
I love this tractor. I bought it because my efforts of maintaining a planted pine field with my Craftsman failed. I had it cleared, smoothed, and thought my big Garden Tractor with a 54" blade would handle it. It wouldn't. I'd never driven a tractor before I bought this Ford. I love the tractor, the way it looks and the way it runs. Had a little trouble at first, it had something stuck in the air intake to the carburetor. I got that fixed, and it purrs. I have a five foot bush hog mower and a cultivator (haven't used it yet). I bought it seven miles away from home and had to drive it on the highway. Got it up to 21 MPH.
Pros: Most everything.
Cons: The hydraulics seem weird. The mower won't stay at the height I set it to.
Photo Uploads:
4.00 star(s)
Anonymous Poster
640_2 Ford
Great older tractor
Model Year: 1956
Gasoline tractor. I am a weekend warrior. It is currently on our family farm in VT. used in the fields and woods. It came with a Lord loader and 2-speed primary (overdrive). It is well matched for 60" brush hog and 72" 3PT finish mowers (though more power would be nice). A 7 foot 3PT sickle bar is no problem. The 'live' 3PT hitch makes mowing much easier (than 8N). With a TSC 3PT lifting boom it moved large trees and 1000 lb machines. It has handled a frame mount back-hoe and a 3 PT hitch backhoe well. 3PT log splitter and bback-hoe work well off loader hydraulics. Gas engine helps with starting in winter.
Pros: 'Stone' reliable
Cons: No PS,
[ad placeholder]
Ford 640_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner Ford 640_2s
Ford 640_2 Community Rankings
#49 user rating of 679 Vintage Tractors items
#15 Viewed of 679 Vintage Tractors items
#20 discussed of 679 Vintage Tractors items
#998 user rating of 19625 items overall
#287 Viewed of 19625 items overall
#381 discussed of 19625 items overall
