Dongfeng DF-304 3.50 star(s) (2)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Dongfeng DF-304.
25-50 HP Tractors
About the Dongfeng DF-304
Dongfeng DF-304 Discussions (0)
Here are the most recent DF-304 topics from our community.
No discussions tagged.
[ad placeholder]
User Reviews (2)
Read what TractorByNet members think about the Dongfeng DF-304 Subcompact Tractor
5
0 %
4
50 %
3
50 %
2
0 %
1
0 %
4.00 star(s)
Anonymous Poster
DF-304 Dongfeng
Addition To Previous Review
Model Year: 2011
One irritating property is the condensate that forms in the instrument panel. It must have come with the tractor and does not disappear even on warm summer days. It might be a source of future corrosion and dysfunction of the electronic devices. There should be instructions on how to open and dry the instruments (by silica gel?).
Pros: Value for money, so far.
Cons: Requires regular service.
3.00 star(s)
Anonymous Poster
DF-304 Dongfeng
Two Years with a Dongfeng 304
Model Year: 2011
The tractor is supplied with a Changchai 30 hp 3 cyl. diesel engine. It operates readily. However valves need control and adjustment rather soon after delivery. No 3 cyl. inlet valve had a lash of 0,7 mm (required 0,25-0,30 mm). The PTO lever and users manual states wrongly that PTO lever should be in a forward position for 540 rpm. When using a rotor cutter at a presumed 540 rpm, it was 1000 rpm. The clutch was excessively worn by that. Later adjustment of the clutch is rather tedious, due the lack of visibility when adjusting. The user's manual prescribes a distance of 156,5 mm from the engine flange to the clutch lever tip, near the shaft, which is quite difficult to measure accurately. I made little measure of 79,5 mm to adjust the drive clutch adjusting nut. I assumed the pitch of the adjusting bolt to be 1 mm and leverage to the lever tip to be about 3:1. ( It means that one full turn of the nut moves the tip 3 mm) After some adjusting the correct clutch lever ti. P distances could be reached. The PTO clutch adjusting screw should be 1,0 mm from the clutch disc, the manual says 1.8 mm. At that distance the PTO clutch cannot be disengaged. Some help was received via e-mail by Dongfeng customer support. The Swedish agent was not that helpful. The tractor seems very robust, not elegant but produces the expected service. After some 50 hours, check all important measures like valve lash, clutch lash and change oil soon. The magnetic plugs are overloaded with metal filings.
Pros: Robust.
Cons: Requires checks.
[ad placeholder]
Dongfeng DF-304 Owner Pages
View owner pages to see photos, customization and comments about member-owner Dongfeng DF-304s
Dongfeng DF-304 Community Rankings
#750 user rating of 2355 25-50 HP Tractors items
#576 Viewed of 2355 25-50 HP Tractors items
#683 discussed of 2355 25-50 HP Tractors items
#2135 user rating of 19625 items overall
#1661 Viewed of 19625 items overall
#1984 discussed of 19625 items overall
#14 Ranking of Most-OwnerPages in 19625 items overall
