Backhoe rake is fiinished
/ Backhoe rake is fiinished #1
old cheddar
Prescott Ontario
kubota l2800
I got my backhoe rake finished. Just in time to not be able to use it this year. Got a chance to try it out though and it works better than expected. It rips through roots and pulls small stumps easily. Pictures aren't the best but gets the point across. I origionally had planned 5 tines but it was pointed out that it would be too wide and could bend pins, so I reduce to 4 tines and spaced them slightly closer together, leaving the pipe overhanging a bit. Its roughly 24 " wide now.
I got the parts waterjetted and the flanges welded and reamed by a company in Trenton Ontario, if anyone wants the info on them I can supply it. They were real easy to deal with and reasonably priced. All I had to do was supply them with a cad drawing.
Next project underway already is a tractor cab, then to motorize the chute rotater on the snowblower. Next year to build a screener to get the soil separated from the roots.
/ Backhoe rake is fiinished #2
Looks good, never thought about a back hoe rake.
I tried ripping the roots with a rear mounted ripper but that just rutted up the land. Additionally, I have a lot of tight spaces to maneuver so the rake is much more nimble. The roots are unbelievable. Above ground is just a few junky looking bushes, below ground, I have an underground forest.
/ Backhoe rake is fiinished #4
It turned out great!
How did this end up working out for you? Did you add a thumb with it?
/ Backhoe rake is fiinished #5
Man, very nice, I love this! Old Cheddar, this thread needs an update.
/ Backhoe rake is fiinished #6
The OP hasn't posted since 2016.
/ Backhoe rake is fiinished #7
Well he may just read w/o posting nowadays, who knows. Either way the dude deserves props, this thing is sweet.
/ Backhoe rake is fiinished #8
Usually a TBN "member" that tops out with just a few posts was either someone that got his answer and then left, or a shill that makes a couple of benign posts to fit in and then gets to work on his agenda. Not old cheddar. Hope he comes back.
/ Backhoe rake is fiinished #10
that tool would serve him well in middle earth for sure!
/ Backhoe rake is fiinished #11
I need a backhoe rake in my life.
I found a fella on youtube who fabricobbled something interesting. Smart, I think I'll borrow from his design.
/ Backhoe rake is fiinished #12
i wonder if they have static pictures of the "rake" somewhere of if some else screensnapped a few elsewhere?
/ Backhoe rake is fiinished #13
Maaaaaan, how is this not a thing to have?!!
/ Backhoe rake is fiinished #14
Gofast, I'm looking at you, bud!
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2018 John Deere 470G Hydraulic Excavator (A61572)
2018 John Deere...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2015 Teupen TL54J Crawler Articulating Boom Lift (A61572)
2015 Teupen TL54J...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A61572)
2025 Kivel Fork...
