Homemade Root Ripper
   / Homemade Root Ripper #1
North Texas Mike
Gunter Texas
2005 Kioti CK25, 2016 Gravely Pro48 Zero Turn
Recently acquired a 2005 CK 25 Kioti with a FEL and BH, my biggest problem with the backhoe was the little 2375 came with a 16-inch bucket digging around stumps and roots was a difficult so I decided to make myself this little deal... it is made out of half inch plate and I added quarter inch to each side making it a full 1 inch thick. I also added a removable tooth that I picked up at the local Tractor Supply, so far it has worked like a champ back to Happy Trackoring 20170807_200918.jpg20170807_200840.jpg20170808_194806.jpg20170807_201147.jpg20170807_201121.jpg20170807_200309.jpg
   / Homemade Root Ripper #2
This is one nice tooth. Nice clean job too. I'll just bet that rips roots, brush and debris.
Thanks... with the marvel of lasers these days it makes it pretty easy to do custom Fab
   / Homemade Root Ripper #4
It is a neat job. Only negative to me is the work to change bucket to tooth. I know for I do not have a quick change bucket system either so you just have to plan your work. Would be a trick to come up with a design that folded down for use and then up when not needed. I am sure many have looked at that.
Will say do not over look using it for trenching for cable or plumbing water line or such. Should work very well if it will be deep enough. But no doubt really helps at breaking those roots.
   / Homemade Root Ripper #5
That ripper looks AWESOME!! Teeth all the way from top to bottom. Laser is good, but I only have O/A torch. Any build pics or computer/CNC docs? About how long is the tooth? I have a Mahindra Max 28 with a backhoe, but a dedicated ripper is what I need. Buckets don't cut it for stump removal.
   / Homemade Root Ripper #6
What kind of back hoe do you have on your tractor ? does it have it's own hyd. or do you use the tractors hyd. ?
   / Homemade Root Ripper #7
It is a factory add. It uses the tractor hydraulic system. Equipped with 8", 12", 16" buckets.
   / Homemade Root Ripper #8
Awesome Jon making the ripper. Do the teeth help?
KUBOTA U55-5 EXCAVATOR (A59823)
KUBOTA U55-5...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2023 CATERPILLAR 262D3 SKID STEER (A60429)
2023 CATERPILLAR...
2012 Mini Cooper Coupe (A59231)
2012 Mini Cooper...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
12' CONTAINER (A52706)
