Front end loader homemade small tree transplant tool
/ Front end loader homemade small tree transplant tool #1
areid
Lloyd Sk.
B3030
I'm hoping someone has done this already but I would like to build a small spoon type device to lift small trees out of the ground for later transplanting. I have access to several 1 - 3 foot pine trees I'd like to transplant. I would really like to just have some sort of a spoon I could work around the tree and pull up a small divot. Using a Full Bucket would be Overkill and hard to cut through the grass. My plan is to use something lightweight but strong enough to cut down around the tree 8 to 10 inches deep. If any of you have built something like this I'd love to see it. I'm thinking it would be something like a potato digger backwards. 20180511_160723.jpeg
/ Front end loader homemade small tree transplant tool #2
Google bucket spade
/ Front end loader homemade small tree transplant tool #3
I built a tree spade for removing trees. I guess it might work for transplanting. Understanding that you also have to "spoon" out the same amount of dirt from the receiving location.
For trees that small a spade would work fine.
I agree some are small enough to move with a pail and a shovel but the three foot trees have a pretty extensive root structure already and I would rather use a curved spoon device on my loader to get the majority of the roots so there is a good chance of survival. I hired a tree mover to move 25' trees 9 years ago and they are just now beginning to grow again. Messing with the roots sets them back a long way. 20160612_214438.jpeg
/ Front end loader homemade small tree transplant tool #8
I hired a tree mover to move 25' trees 9 years ago and they are just now beginning to grow again. Messing with the roots sets them back a long way. View attachment 553801
WHOLE lota difference in the root structure of a 3' tree and a 25' tree. I've moved a lot of 2-4' white pines, it barely slows them up a year....by the second year, lots of new growth.
I use a 3' bucket on the excavator, because I have it. But those shovels on the FEL on Google look good.
Here is what I made in 5 hours out of scraps I had laying around. I used a drum roller I haven't used in years for the scoop. I also have a homemade attachment I built for forks but I had a lot of difficulty finding strong enough forks. I decided to make the spade detachable. I can easily drive up to it and scoop it up then add the two bolts to keep it in place. I also wanted to make it so I could slide it a foot or so either way if I got into tight conditions. I tried it out on a 20 foot poplar in my pasture and an ant hill
(something I didn't think of head of time) and it worked great. I think it should get enough roots to lift out a four or five foot tree for transplant.
I'm happy with the results. 20180512_104555.jpeg20180512_161058.jpeg20180512_161553.jpeg
I wonder how deep a trench I could dig? I'm thinking I could set it up to dig while backing up. Another modification for another day
Picks up rocks better than the bucket. Also ants that went for a swim in the dugout, take that! Hope this post inspires someone to do something better. 20180512_162916.jpeg20180512_162420.jpeg
/ Front end loader homemade small tree transplant tool #13
Pretty cool, you can just dig and move forward to dig a trench, the spoils will fall to each side. Some will fall forward, but just keep on digging and the loose dirt will eventually fall to the sides. Dig and flip, move up inches, dig, flip and move. Kinda of like a hog rooting in the dirt. It works.
