Building a bridge over a creek (driveway)
   / Building a bridge over a creek (driveway) #1
Softcoin
john deer 3032
I bought a piece of property that has a creek in the front of the property.
There is a wood bridge there now, (20 years old) 7 sets of 5 2"x8"x15' boards bolted together w/ cross boards on top connecting them all and runners on top to drive on.
There is a concrete pad on each side of the creek 2ft thick x 12ft wide x 6' deep.
I'd like to replace the wood with 8" or 10" i-beams (as many as it takes) and connect them all with cross boards and runners.
I-beams would be 15' long sitting on the existing concrete pads, concrete pads are 13' apart. so the i-beams would be sitting 1ft of pad on each side. see attached
Does anyone know if this would be strong enough for a single axle dump truck full of gravel?
   / Building a bridge over a creek (driveway) #2
a fully loaded tri axle dump truck at 72,380lbs? You better get a Professional Engineer to design this and seal it. There is a big difference between a W8x15 and a W8x67 or a W10x19 to a W10x112.
   / Building a bridge over a creek (driveway) #3
There are online calculators for beam strength which would be a good start for you.
   / Building a bridge over a creek (driveway) #4
This chart should help you figure out what you need.
Keep in mind, the shown ratings are per beam. Multiple beams should be cross braced so they can't roll under a load.
The bigger question is what are you using for decking. The wood decked bridges I have set all use 3" thick plank layed cross wises to the beams, then 3" runners on top of that. But, most bridges I have set use the corrugated steel decking, then get gravel or asphalt on top. For your purposes the wood deck would do fine.
   / Building a bridge over a creek (driveway) #5
Call up a couple local steel yards and tell them what span you are trying to cross. Sometimes they end up with short sections that they will sell for a much better price than if you specify what you want. Often they can even tell you how much they will support (it'll be not as detailed as what an engineer can tell you). From there you can decide if it'll work for what you want to do.
About 20 years ago I helped my step brother build a bridge for his driveway. He got 7 19' I-beams (forget what size) and we painted then spaced them out. He had a welder come up and put in cross pieces after we got them in place. We then laid down pressure treated 2x4 bolted together with threaded rods. The data he got was from the steel company and the bridge has handled everything from tri axle dump trucks fully loaded with gravel and cement trucks to build his house.
   / Building a bridge over a creek (driveway) #6
Years ago I drove a single axle dump truck hauling pool sand.
The pit ALWAYS scooped from the bottom of the pile getting the wettest/heaviest sand!!
My worst load was 33,000 lbs gross weight and it was heavy.
This should give you a maximum number to work with.
   / Building a bridge over a creek (driveway) #7
The last bridge we did decking was unplanned treated red pine 4x8's. It was designed so a pickup truck could use it. I beam spacing was 3ft centers (as I recall anyway). What about a fire truck?.
   / Building a bridge over a creek (driveway) #8
an I beam sitting between the tires wont do squat unless the decking is pretty stout.
a single axle can be rated for over 30,000 lbs on its own (think I saw as heavy as 38,000lbs for a Freightliner SD single drive axle), so an overloaded single axle might be over 20 tons. a standard heavy single axle rating is 20,000 lbs.
   / Building a bridge over a creek (driveway) #9
The loads on this bridge would actually be pretty small just because the length is so short. While it is true a triaxle truck or fire engine might roll across it, bridge calculations are done on length and weight. In this case, even if a tri-axle truck did roll across the bridge, because the bridge is only 13 feet long, that means the entire weight of the truck is never fully on the bridge. (The front axle is on the bridge, or the rear axles are on the bridge, but never the full weight of the truck.
It still leaves the three rear axles over the bridge granted, but then that load is spread over 12 tires.
The best way to deal with that is, to put down (4) I beams at truck width, angle irons welded x fashion between them so they do not twist under load, then plank the bridge over with 3x8 planking. I would add bumpers on the outside, or railings depending on height. (Just to limit the liability of kids or grand kids falling off if it is high).
I would not over-think this too much.
   / Building a bridge over a creek (driveway) #10
Sometimes you can also find used bridge steel for sale.
   / Building a bridge over a creek (driveway) #11
That is why I discussed highest single axle load.
   / Building a bridge over a creek (driveway) #12
Calculated a bridge with a 10 meter span over a canal for a friend, because the water council needed a calculation for a permit. I calculated four beams HEA400 but he could only buy 9 at a time, used. It can hold a 60 ton dumptruck with a safety margin of two.
As bridgeheads we used inverted T shaped concrete retaining walls used for silage silos, i calculated the lateral pressure as given by the manufacturer, into vertical pressure when used as foundation and it had also a safety margin of 5. Ground pressure was far lower than the lowest rating for the soil in our area, and we buried them deeper than the canal bottom so underwashing of the foundation was impossible. Another friend took the telescopic crane from work to place the bridgeheads so he had a fully licensed 12 meter span, 4 meter wide 60 ton bridge for under 5000 euro.
   / Building a bridge over a creek (driveway) #13
I've seen people use old flat bed semi trailers. Don't know weight capacity of one but normally are 40' long and 8' wide. Cut in half and you have a 16x20 bridge that probably would hold almost anything you'd need it too.
   / Building a bridge over a creek (driveway) #14
Nice bridge discussion.
rScotty
   / Building a bridge over a creek (driveway) #15
Find a demo company and talk to them. They scrap a awful lot of good stuff from building demo jobs.
   / Building a bridge over a creek (driveway) #16
Some counties and states have been using thick micro-lam beams on shorter spans like this. Not sure why... maybe less maintenance using wood versus steel.
   / Building a bridge over a creek (driveway) #17
wood is cheaper than steel.
   / Building a bridge over a creek (driveway) #18
We had to redo the bridge at our cabin. There are about 20 properties that are only accessible by way of this bridge. THe beams are from a railroad car that crashed in the 1950's and repurposed. The steel has lots of nickle in it and even though we get 20 feet of snow some years, rust in never an issue. I wish we could get steel like that now...
One of the guys up there is a engineer in the oil field and knew about these rig mats used by oil field drillers. He had them made up for our purpose, width and length. These things are strong and durable. It was quite the job to remove the old creosote soaked timbers and shore up the abutments and lay the new decking. It's nice now though...
What ever you do, over build it and make sure your abutments are strong and stable.
   / Building a bridge over a creek (driveway) #19
When I bought my farm 20 years ago, I found that I needed a bridge across a creek than ran across the back of my property. Wasn't any way to get to the rest of the acreage to mow without getting on the neighbors land. I bought a used unserviceable 53ft. flatbed semi trailer that had been run under a bridge and the load hit. It took some of the crown out(about 6 inches) and ruined the wood flooring/floor cross supports. I got it for bought and delivered for $1000. I replaced the flooring, removed all the stuff I didn't need and put it over the creek and removed all axles, landing gear etc. welded it to fence posts at the corners and welded fence posts and rails across it. Worked perfectly even when the creek flooded a couple of times. I drive my tractors across it and since it was rated for 80K I figure it will handle anything I will ever need.
   / Building a bridge over a creek (driveway) #20
When we built here back in '89 I went to a real engineer and had him design the bridge. We had a temporary OK from the neighbor for the construction traffic to use a corner of his field so we could proceed with the work before the bridge was built. Part of the project included re-routing the creek (removing a large lazy omega-shaped bend). According to the engineer and DEP, straightening the creek offset placing the bridge in the floodplain. Did I mention the approval process took three years?
Anyway, it worked out well because we built the bridge on dry land and then re-channeled the creek to flow under it. I told the engineer I wanted a bridge that would be good for trucks in case we needed triaxle loads of stuff, or something bad happened and we needed a fire truck. I believe the footers are somewhere around 11 feet below grade.
The picture that shows the bridge is looking West, or upstream. The picture with the bridge hiding in the water is looking North during a high water event that happens about 2 or 3 times a year. The driveway curves slightly to the left after getting past the trees and if you look closely you can see the two sides of the bridge. At that level, the deepest water on the driveway is less than a foot. There have only been a few times since we built that we lost access. When that happens, it only lasts for maybe an hour or two. The worst that happens is I get to spend an hour or so gathering old soybean stems, pieces of cornstalks and someone else's firewood.
EDIT TO CLARIFY: Although this is the BIY area, the builder who did the house built the bridge. Since I've had some experience at work, I was thinking about doing it myself. When the builder said he could name that tune for $7K I told him to have at it. I had a price from one of our vendors of over $1K for the rebar alone. I had plenty do do in the house at the time - electrical, plumbing, HVAC, central sucuum, security system, etc. It was a busy 9 months.
2022 THOMPSON PUMP 6X6S1 PORTABLE PUMP (A59823)
2022 THOMPSON PUMP...
UNUSED FUTURE PC71-71" HYD PLATE COMPACTOR (A60432)
UNUSED FUTURE...
2020 Ram Promaster City 1500 Cargo Van (A59230)
2020 Ram Promaster...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Club Car Carryall 500 Utility Cart (A59228)
Club Car Carryall...
Traxmax Kubota Stand-On Track Loader Skid Steer (A59228)
Traxmax Kubota...
