Front loader carryall
   / Front loader carryall #1
dooger54
I'm looking for ideas on how to add a "carry-all" to my front bucket. I did some searches and couldn't find anything although I know I've seen them here before. I need to add a platform of some kind so I can more easily transport larger items, like my pressure washer, around my property. I do have a welder. Would like something that is easy to add/remove.
   / Front loader carryall #2
I think the ones you've seen were home built items.
Take a look in the "Build It Yourself", "Projects", and "Welding" forums.
   / Front loader carryall #3
Not sure what kind of tractor you have, but I have quite a few posts regarding building my carrall and setting up a loader-mounted quick hitch that might give you some ideas. Search for my posts in the Build It Yourself forum.
   / Front loader carryall #4
You could use a set of forks and build any type/size carryall you desired out of wood.
Or use a loader mounted receiver hitch and slide a conventional carryall into it.
You could also get a a 3pt carryall from tractor supply for small money.
Here's one monster box I built to handle leaves, also makes a nice work platform for reaching higher places. but this does require you to have the forks.
JB
   / Front loader carryall #5
I took 2 pieces of C-channel, and notched them to slide over the bucket, like forks. Then I can put plywood over them to make a large flat work area. You may want to re-enforce the sides if you intend to use them on very heavy loads. The nice part was, the materials cost very little.
My tractor is a NH 35 with 6' FEL. I wanted the platform to load from the front so I could keep another implement on the 3pt hitch. Seems like my sprayer or something else is always attached to the rear.
I hadn't thought of the other forums suggested. Will do a search for on those also.
   / Front loader carryall #7
I have the same situation. I really like being able to just grab the carryall on the front and go, without having to drop the mower, chipper or whatever is on the back.
   / Front loader carryall #8
Thats Nice! :) The whole dang work bench! ;)
I like it cause the older I get the less I like working on the ground, this way I got a small bench to work off of!:thumbsup:
   / Front loader carryall #9
That is very nice!! You're set up for the whole day!!
Is that box on forks, or did you build a QA hookup on it?
Runner-
Do you have posts anywhere showing how you constructed that??
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
