Installing rear hydraulics on L3130?
   / Installing rear hydraulics on L3130? #21
Davidson.
What did you think of the installation? Was it difficult? Also what was the most difficult part of the installation you encountered? If you don't mind, what was the cost of the kit??? Thanks..
John
   / Installing rear hydraulics on L3130? #22
John,
I have a L5030 cab, and getting the seat off and out of the cab was the hardest part for me. It was not difficult once the seat was out. On top of the pump is a cover (2 bolts) that has to be removed. If you have a cab the mounting bracket for the valve has to have spacers to bring it out about a half an inch. I put everyting pretty much together before installation. I put the rear outlet's together and had them mounted before installing the valve. I had the hoses attached to the valve when I attached the valve to the pump. After putting it in place I had all the bolts in but not tighened in case I had to adjust, when it was right I tighten everything up. You'll have to have a torque wrench for bolting the valve parts together and bolting to the pump valve mounting bracket. The instructions have torque specs for the hoses but I did not see a way to measure that. All in all it was not as bad as I expected, but if I had it to do all over again I would have ordered a second set. I don't need a second set right now but I could not image having to break it down again to add one when it would have been so easy with the initial installation. Cost for the base kit for me was $635 with shipping. Hope this helps.
JD
   / Installing rear hydraulics on L3130? #23
Thanks for all the info you provided. I might call around and see if they have them in stock around here.. Glad everything went smoothly for you. I'm sure you will get a lot of use out them...Thanks again...
Hey my parts came in today! I'll take some pics of the parts and as it goes together. Might be a couple days, now that I'm busy with other stuff.
Well guys I'm back! I'm going to upload some pics if anyone is still interested?
I ran into trouble with the install that I will go over. This is what the kit looks like.
   / Installing rear hydraulics on L3130? #26
Bill,
Good luck with the installation. Glade you finally got all of your parts. Keep us up to date with photos.
An old farmer friend of mine once told me that the difficulty factor for any mechanical project was based on how many sheets of plywood it took to lay out all the parts needed for the job. It looks to me like you have a one sheet project.
RPK
I read the instructions all the way through, then looked at how everything fit. I decided to assemble as much as I could on the bench. I didn't remove the rear tire like some one suggested, I think the little inconvenience out weighed the extra work of removing the tire.
   / Installing rear hydraulics on L3130? #28
Bill
On my L3130 the lever for the #1 valve drags on the side of the slot. You might have to do a little judicious bending if you run into that problem.
Vernon
Thanks tex, mine was dead center. My problem was I had a bad casting, or something got under the plate on the cylinder control center and ate the cast, look at the pic with the cover off. It's on now with two bolts and needs three. Dealer is ordering a new casting. For guys that haven't done this, these pic are under the seat where most of the work is done.
Up date, I just got my valve body to replace the stripped bolt holes. I told my dealer that I would change it at my next major service. Also a couple pics for justcountry, and welcome to TBN.
   / Installing rear hydraulics on L3130? #31
Thanks a million Bill, those are the exact pics I was looking for. Now I know that the 10 series valve is diff than the 30 series. I had a local guy trying to selll me one for a 10 series and he said it's exactly the same as the what goes on my 3130.
   / Installing rear hydraulics on L3130? #32
Bill--thanks! You've completely cured me of adding my own, rear remotes. My visions of a simple, external valve body, some Teflon tape and a happy ending are over--and I'd love to pay the dealer the extra few hundred for that labor.
Is it basically as involved on a B26630, for rear remotes?
Are adding front remotes a much simpler prospect, or just as intimidating as what you documented so well re: the rears.
Congrats, by the way--looks great!
Oh--about how many hours did it take you? And I'm guessing this wasn't your first time at the rodeo, with such an upgrade? Or do you work as a "wrench" in the day? (If you don't mind me asking.)
Thanks.
My Hoe
1408 (A57192)
1408 (A57192)
2021 Ford Mustang Mach-E AWD SUV (A59231)
2021 Ford Mustang...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59905)
2018 VOLVO VNL...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
