BX2350 CCM Top Link
   / BX2350 CCM Top Link #1
actionaj
Gold Member
Southern Illinois
BX2350
I installed my new CCM top link cylinder a couple of weaks ago. I have to say that a hydraulic top link is the way to go when using a box blade. Adjustment at you finger tips brings box-blading to a new level. CCM is great to business with and the cylinder is of the highest quality. The cyl. I ordered is 14.5-20.5 stroke seems to be the perfect length so far with all my attachments. Here is some pics. with BB.
   / BX2350 CCM Top Link #3
I was just going to order a similar toplink. I have the Kubtoa remote kit on order. Did you have CCM make up the hoses? What size are the quick disconnect couplings?
I made the hoses myself at work. They are 1/4" Parker hoses with male 1/4" NPT ends, the cylinder end I used a straight swivel, the QD end I used just a plain straight. Total length from fitting to fitting is 30". I changed the fittings on the check valve from male 3/8" NPT to 1/4" female NPT using a Parker adaptor I don't remember the part number for this but the threads in the vale are SAE-M (I think). The QD's I order from Snap-tite's web site. Part #72N4-4F they were $5.87 each.
   / BX2350 CCM Top Link #5
Crossfire, is the Bota kit expensive?
   / BX2350 CCM Top Link #6
The kit is $284 - part number is BX7326. From reading other posts, I thought I needed an additional hose kit - my dealer didn't know too much about it - he called Kubota and they said that was all that was needed. It is supposed to come in at the end of next week. We shall see... I am going to attempt the install myself and see what happens.
This is for the BX2350 (not the BX24's).
Crossfire190 Here is the link to my post on installing the BX7326 kit.
http://www.tractorbynet.com/forums/kubota-owning-operating/125660-bx7326-rear-aux-kit-install.html
   / BX2350 CCM Top Link #9
Well... I am still waiting for the valve kit. The dealer got one in, but the box was torn in route and 1/2 the stuff was missing when I went to pick it up, so the dealer has ordered another kit.
Actionaj - did you use any tape or pipe compound on the fittings?
I am not familiar with "crows feet line wrenches" - where do you find these and what do they do?
Thanks.
Thanks.
I used Teflon-tape on QDs only, I put the tape on the male pipe threads one thread back from the end and 2 wraps of tape. All the other fittings are flared or o-ring they do not require any sealer.
Crows feet are open end wrenches that attach to a 3/8s drive ratchet extension. Line wrenches are kind a like a box end wrench that is open enabling it to slip over the steel tube and grab the fitting allmost all the way around makes for a firmer grip on the fitting compared to a standard open end wrench. You can find them at Sears. I ended up using a combination of both, plus standard wrenches and line wrenches.
Sorry about your kit being messed up the box mine came in was really ruff too the parts guy went through it and made sure that all the parts were there.
Don't forget about the bolt that holds the valve on to the transmission being wrong my kit came with a 12mm bolt the correct bolt is 8mm.
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
Unused 2025 CFG QK20R Mini Excavator (A49461)
Unused 2025 CFG...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2003 Lincoln Aviator (A50515)
2003 Lincoln...
2018 John Deere 460E Articulated Dump Truck (A52128)
2018 John Deere...
8 Ft Fork Extensions (A50322)
8 Ft Fork...
