ford 1700
   / ford 1700 #11
JC-jetro said:
I paid $3100 for it. is that a good price?
Thanks
Yes
I had a 1710 for many years and loved it. Stepped up to a 2120
Andy
   / ford 1700 #12
AndyMA said:
Yes
Andy
Thanks Andy,
I have checked my hydraulic/ transmission fluid and it looks perfectly clean, no sign of condensation. Took a lighted scope inside the transmission from the oil fill hole, gears are in perfect shape and no sign of wear or damage. The owner manual and also repair manual recommends replacing the whole hydraulic fluid every 300 hrs. My tractor has 900 hours and I do not believe the Hydraulic fluid has ever been changed.
Have you ever changed the entire hydraulic/transmission fluid?
I'm aiming to do it, but need to clean the suction strainer in the rear housing. That requires removing suction piping from hydraulic pump driven off of crankshaft gear(live) to the rear end allowing removal of the strainer. Strainer is a stainless steel mesh drum that filter things out. It is a lot of work and I don't mind to do it, but just don't know if it is a normal procedure a lot of tractor owners do. I appreciate your opinion. Would encourage others to chime in. Ford 1700 is my very first tractor purchase.
Thanks
   / ford 1700 #13
ronhampe said:
Hi all, just came across this forum and its great!
I've put over 3000 hours on this tractor (3985 total hours) and am ashamed to say that I didn't know that the injector pump had oil in it, let alone that it needed changed periodically. Just looked again and still don't see a sight glass though. What type of oil do you use in these?
Thanks and Have a Great Day!
Ron
Ron,
I made a post in reference to F-1700 fuel injector oil. it is pretty simple to do. The injector oil is basically the same diesel grade oil you use for the engine. Please refer to the post below.:)
JC
http://www.tractorbynet.com/forums/...52-injector-pump-oil.html?highlight=ford+1700
   / ford 1700 #14
I just bought my neighbours 1700 Ford. I looked after his tractor which he never used because he was and absentee landowner. I love this 2 cylinder 4 wheel drive machine. It was always parked inside the drive shed on his land and has no UV damage on the paint and tires. I changed all oils and am using it right now to split firewood. It came with bush hog, blade, splitter and a 3 point hitch crane. It has 700 hours on the clock and uses no oil and drips no oil. I am determined to keep the 1700 in mint shape. wolf (I have owners manual for it if you need a copy let me know.)
   / ford 1700 #15
   / ford 1700 #16
Glad to hear that, 1700 is one sweet little mule. I would have been happy as a lark if i had, FWA, Power steering and FEL on my 1700... That's all :D:D:
I have whopping 950 hrs on it and it just getting broke in, I will get a another one probably brand new sometimes down the road with all the things I'm missing but have no plans to part with my 1700. I like the good design and simplicity of maintaining it.
JC,
   / ford 1700 #17
I have a Ford 1700 that I have owne for two years and have changed the hydraulic/transmission oil on three times now. It turns a milky white and the hydraulics start acting goofy. Can anyone offer advice as to where the water might be getting in. I am assuming it is water. The last time I tarped it and still did it.
   / ford 1700 #18
It must be water. There is a breather cap behind the seat that might introduce a bit of water in to the rear differential. Do you have the breather cap in there?
There is rubber hand hole on the right side of the clutch housing, take it off and take a peek inside with the aid of a flash light. There should be no water there. If the transmission input shaft seal is bad and you have water in there then there is potential to get water r in the hyd system. How is your engine oil looks like? they are separate but through crankshaft oil seal you might also be getting water in to the engine oil.
3 times of oil change but are you sure you removed all the oil from your system? did you clean the inlet screen? did you drain the oil from the differential housing? you'll have more than couple of gallons oil in the differential left if you just drained oil from transmission housing.
Your answers might shed some light to solve the mystery.
JC,
By the way , welcome to TBN Blue:)
   / ford 1700 #19
Thanks for answering back. Yeah I cleaned the metal screen and drained the differential. It was the lowest point to drain from. I wasn't sure if I should change the oil back to back to get as much of the contaminated oil out? I'll have to check on the breather and the clutch hole. I didn't know about those. The only breather I knew about was the one on top of the transmission housing by the gear shifts. The engine oil is not contaminated. Any other things to check while I am at it?
   / ford 1700 #20
Just to make sure the screen filter is the one that the main hydraulic oil comes into and the screen filter is held in by 4 bolts. The filter is about the size as a water filter from a well correct?
GM 4030-C 6 Cylinder Power Unit (A57149)
GM 4030-C 6...
2022 Deere 325G (A57148)
2022 Deere 325G...
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A58376)
UNUSED JCT 84" HYD...
INSPECTION (A57453)
INSPECTION (A57453)
Rotary SPOA9-200 Automotive Lift (A56858)
Rotary SPOA9-200...
Takeuchi TL10 (A57148)
