Trailer size for B21
/ Trailer size for B21 #2
Hi Bruce and welcome to TBN.
Get a 16' or larger, the 16 foot will be fine for the TLB, but you never know what you'll get for attachments , you may need more room.;)
I found a great deal on a 7'x14' with electric brakes. Do you think it would work the TLB without extra attachments?
/ Trailer size for B21 #4
I went out and measured my B21 and with the front bucket on the ground and measuring to the rear of the backhoe bucket I get about 16ft. 6in. and it's a little less than 5 ft wide. So unless you want some of the tractor hanging off then get at least a 17 ft. long trailer.
/ Trailer size for B21 #6
You may already know this but I didn't until I started trailer shopping. Get dual axels, I started asking people about which trailer to get and several told me to make sure it was dual axel instead of a single axle but they didn't know why except for weight capacity. A single for weight capacity would have worked for me. Finally my brother in law who does alot of trailering cars and heavy industrial machinery told me why to get the double axle. If a tire goes down on a single axel you can be in deep dookie where a dual will probably keep you going till you can get it fixed. I bought dual axel.
/ Trailer size for B21 #7
You may be able to angle the backhoe hoe bucket off to one side and shorten the overall length of the tractor. Not sure if you would gain enough to fit the 14' ?
/ Trailer size for B21 #8
Another reason for dual axles is if you have a blowout at hwy speed w/ a single axle and close to 2 tons of trailer/tractor fishtailing behind you, you will learn the true meaning of a panic stop.
/ Trailer size for B21 #9
That's the "Deep Dookie" I was talking about.
/ Trailer size for B21 #10
I have an old horse trailer I am thinking of cutting the top off and adding to the length to haul my BX. It would keep the center of gravity low and it is duel axl.:eek:
/ Trailer size for B21 #11
Yeah, if you pulled the backhoe bucket fully sideways you can save about 2 1/2 feet, but it gets 1 1/2" foot wider so you would have to park very crooked to get it to fit a 14 x 7 ft. trailer.
Dual axle trailers are much more stable when functioning normally as well.
/ Trailer size for B21 #14
I think there are a couple more questions to ask...1)just how good is the deal on the 14' trailer, and 2) how much do you actually trailer the tractor.
I tow mine maybe twice a year. I built my 14' knowing I would have some things hanging off the back. But if I made it 16' or 18' all it would mean is the cost would have gone up and the tail wheel of the RC would be on the trailer. Not worth it IMO. If I had a FEL, I would do like 99% of the other folks in Texas do, lift it up and keep it above the pickup bed and move the tractor forward more if needed. The deck on my trailer is also 7.5 wide so I have some extra room up top.
Rob
/ Trailer size for B21 #15
I would keep the top on if the BX will fit under it. No worry about the COG because a couple horses or bulls can out weight or be near a bx in weight. And if you lenghten it, be aware of the geometry of the trailer. A standard utility trailer will have the center of the dual axles at about 60/40 to the deck lenght. Put to much weight behind the axle and that trailer will do some serious wagging!
But a covered trailer would be high on the cool list!! :D
/ Trailer size for B21 #16
I did think of the wagging affect, but I think I should be able to add 24 to 30 inches do to the fact that the way the horse trailer is made. The wheels are all the way to the back now. And I would like to keep the top on but the rot is all above the fenders and I would still have to take out the center support anyway.
/ Trailer size for B21 #17
I haul my BX 23 with a 6*10 single axle trailer and it fits great. I raise the bucket up and drive the tractor to the front of the trailer and tie down the front axle to the front of the trailer. The backhoe comes to rest on the back edge of the trailer. The trailer is rated for about 3500#. I don't understand why some think you need a 7000# trailer to haul 2800# tractor. I've driven from Southern Arizona to Colorado and never had a moment where I thought the trailer was inadequate. If you have a bigger trailer, that's great, but a 6*10 works well.
/ Trailer size for B21 #18
I think you are right about that horse trailer and the wheels. I forgot to mention my BIL's...brother has a trailer build for his old L175. He hauled horses and the tractor (not at the same time!! :D). No ROPS on the mid 70's L and the trailers top had a tube frame and canvas top.
/ Trailer size for B21 #19
Amen!! Not to mention 10,000# 20' trailers for a BX. Must spend more time hauling the tractor than driving it! :D :D
