TC40D 4wd drive problem
   / TC40D 4wd drive problem #11
AndyMA said:
Rick
When that happens does it usually shear off some of the teeth from the ring gear? What other damage typically ocurs?
Andy
Depending on the circumstances, just a cleanup & new hardware, or as bad as ring & pinion as well as the diff carrier and gears if enough metal filings have run through them. I don't think I've ever seen a split housing. The longer they run loose the more damage occurs.
Can someone tell me how to split the differential? I don't have a service manual.
If you take the bolts out holding the left side can you slide the whole assembly off , housing,hub,shaft,etc, without taking the hub apart?
Or can somone tell me the best way?
   / TC40D 4wd drive problem #13
As far as I remember you can pull it apart by taking the bolts near the pumpkin out.
I split the front end the differential housing had 7 broke bolts there was only 1left. I could easily take it out with a socket. I got all the broken bolts out and there was thread mark inside the housing telling me they have been coming lose for a while. On the only bolt left that I took out had about 15 degree angle on the head telling me again the bolt were backing out.
It looks like I need all 8 bolts plus housing. I think new holland should take care of this that to me is a defect.
   / TC40D 4wd drive problem #15
Take it to your dealer; hopefully, it will be taken care of.
   / TC40D 4wd drive problem #16
I just bought a 2007 TC35DA. Is this problem something I have to worry about, or did NH fix it in my year of tractor? Love the site and I love my NH TCS35DA. I decided on NH after comparing Masey Furgeson, John Deere, & NH. Also NH deaer is a customer of mine, so I know I can trust them! I am going to pick it up tomrrow from the dealer. They installed my rear remotes, brushguard, & 250TL loader. I can't wait to push some snow. also ordered a new 74CSR NH rear snow blower.
   / TC40D 4wd drive problem #17
Congratulations on that new tractor. Be sure to post up some pictures after it is delivered. We know what it looks like, but we love the pictures anyhow.:D:D
I would not worry about the front differential. Ask your dealer's service manager how many of these tractors have had problems and how many he has seen in his shop. I think his answer will be none or very few. Hopefully, you will never experience a problem. I have not, and I have over 1300 hours on my tractor.
   / TC40D 4wd drive problem #19
I have a TC40D and lost the drive to the front wheels and took it to a dealer and the bolts were sheared off the ring gear. I have not got my tractor back but the dealer said they sold alot of these tractors and this is the first one to come in with this problem.
   / TC40D 4wd drive problem #20
Thanks for the email and posting this info Yardstick. Can you tell us a little about how you use your tractor and how many hours are on it?
I always use my tractor on dirt and grass. When working on level areas, I try to stay in 2wd most of the time and also use 2wd when I'm driving on a gravel road. I have 1400 hours on my tractor with no similar problems yet.
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2008 NEW HOLLAND B95 BACKHOE (A51242)
2008 NEW HOLLAND...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
Blue Diamond Quick Attach 6 Way Blade (A50514)
Blue Diamond Quick...
2014 Dodge Avenger Passenger Car, VIN # 1C3CDZAB4EN223470 (A50324)
2014 Dodge Avenger...
2017 CENTAURO TANDEM AXLE DRY BULK TRAILER (A51222)
2017 CENTAURO...
