Diesel Fuel Additives
   / Diesel Fuel Additives #1
sld
Midwest
Ford 1210 / Ford 1710
Hi guys,
I have noticed a lot of stuff lately with the ULSD being used in older engines.
Can someone point me in the right direction as to what additives I should add to prevent any problems? My tractor is a Ford 1210 diesel that has run great for 22 years. I would like to keep it that way.
Thanks,
   / Diesel Fuel Additives #2
In the above freezing months I use Power Service Diesel Kleen +Cetane Boost (gray bottle) and then in the winter months I use the Diesel Fuel Supplement +Cetane Boost (white bottle). Never had a problem with starting or engine smoke and use it in my old Ford F-350 diesel as well.
   / Diesel Fuel Additives #3
Personally I use Texas Refinery Corp.'s DZL-PEP or DZL-PEP Arctic depending on the season.
   / Diesel Fuel Additives #4
In the above freezing months I use Power Service Diesel Kleen +Cetane Boost (gray bottle) and then in the winter months I use the Diesel Fuel Supplement +Cetane Boost Never had a problem with starting or engine smoke and use it in my old Ford F-350 diesel as well.
I use 32 ounces (white bottle). per each 55 gallon drum of diesel.
   / Diesel Fuel Additives #5
No powerservice for me since UOA from DysonAnalysis were not good. SKip it.
   / Diesel Fuel Additives #6
You don't have much choice in the winter if your in colder climates. You either use a anti-gel additive or don't use your equipment.
   / Diesel Fuel Additives #7
I would not say that is 100% correct. There are better products then PS.
   / Diesel Fuel Additives #8
Not good in what way? What was the problem?
   / Diesel Fuel Additives #9
IMHO DieselPower is the "guru" about diesel fuel additives. That said I use PS (White Bottle) year round, double strength during the colder months. I have not had my ULSD :( gel up :mad: since I started to use PS. I have heard that Howes makes and additive that is pretty good as well. BTW welcome to TBN sld :D! Jay :)
PS: Long time since I have seen a post from you DieselPower. I missed your avatar :rolleyes:
John Deere HPX615E Gator 4x4 Utility Cart (A51691)
John Deere HPX615E...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
