Diesel Fuel Additives
   / Diesel Fuel Additives #12
Not good in what way? What was the problem?
Run it and look on your UOA; then run without it and pull a UOA. Talk about high wear #s. My guru is my UOA house and not anyone on here.
   / Diesel Fuel Additives #13
Is that you Frank Miller?:D He was banned the same day you signed up....hmmmm.:eek:
   / Diesel Fuel Additives #14
What? So now when someone signs up and something happens to another member they are the same. Maybe I can be president when he leaves too....:D:D;)
   / Diesel Fuel Additives #15
Only reason I see to use an additive (and a tiny bit of that white stuff pointed out above will do it) is in the winter, to keep the fuel from gelling. About 1/3 tank of kerosene would be a cheaper way to lower the pour point.
Ralph
   / Diesel Fuel Additives #16
Ralph
I have 5 quarts of this white stuff on hand or enough to treat five 55 gallon drums of fuel.
Thanks for the replies guys. I did not want to start an argument.
I don't know much about diesels so I am asking questions. I was concerned that the ULSD would be bad for an older engine or the injector pump.
The temp is not too big of deal as during the winter the tractor lives in a heated garage to clear snow from my driveway. Otherwise, it stays in a barn the other 9 months a year.
I need to keep educating myself.
   / Diesel Fuel Additives #18
I am not an expert, but doesn't kerosene make your diesel engine run hotter? Jay
PS: My diesel supplier has added quite a bir of kerosene to his tank "mix". Since then my engine seems to run hotter.
   / Diesel Fuel Additives #19
I've a 25 year old diesel and don't use any additive. No leaks; no drips; no errors.
Ralph
   / Diesel Fuel Additives #20
Ralph
The problem is, the fuel formulation you ran it on all that time, with no trouble, no longer exists.
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
UNUSED MOWER KING 72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
20ft Bi-Parting Wrought Iron Gate (A51573)
20ft Bi-Parting...
