WarrenF
Gold Member
Generally, most of the ground out here is irrigated with concrete ditches and siphon tubes. There is another method as well, it is called gated pipe. Gated pipe is about a 6 inch pipe with slide opening every 36 inches. You "set" your water by opening the slide gates to the desired amount. If you would like to see a picture of siphon tube irrigation go here.....Siphon Tube irrigation again pictures from idaho photos on webshots.
Here is an interesting development out here. Many who are growing onions, have gone to a drip irrigation set up. They can filter the water enough so the drip lines do not clog.....and they can even "inject" the chemicals needed for a healthy crop right into the drip system. The production level goes way up on fields of onions irrigated this way.
I had occasion to travel to South Dakota around Pierre and east,this past early summer. That is impressive country back there, with farms that were 4 and 5 thousand acres. If you had that size farm out here.....you would have 20 to 30 people working just to keep up with the water. Out there they were farming it with two and three people....IMPRESSIVE.
