can i box in a propane tank?
   / can i box in a propane tank? #1
escavader
western maine
bx-23 ,
Im moving my oil barrel,next to the house,beside the propane tank,and i want to hide,the hidious looking things, and protect them from the snow coming off the roof.Iwas going to build one building around them both,with access doors .Can i close in the propane tank ,or do i have to vent it?It wont be an airtight building,but id like to keep out some of the cold so i dont have to burn k-1 which is getting pricey.
ALAN
   / can i box in a propane tank? #2
Propane tanks are boxed in on boats all the time. The only thing that is done is a weep hole at the lowest point in the enclosure. The hole lets water and propane vapors (heavier than air) escape.
Seems to me that doing the same thing on land would be reasonable enough. That doesn't mean that some authority doesn't have a rule against it. That's your choice. Me, I got rid of the propane. I hate the stuff, but that's just me.
   / can i box in a propane tank? #3
i personallly would, as long as i'd have enough air flow to prevent a build up from a small leak which would obviously create an explosive condition. can you install a steel screen or vent somewhere?
Iguess i could put an interior divider between the propane tank and oil tank,then i could vent it.Any rule of thumb for the size of the vent? It just feeds our kitchen stove only.
ALAN
   / can i box in a propane tank? #5
I sure wouldn't box in a propane tank.
One explosion could ruin your whole day.
It is easy to build a visual screen which allows plenty of air flow. Think boards mounted at an angle, like louvers.
Be safe and build a separate enclosure for your oil tank, you can make that one as air-tight as your want.
   / can i box in a propane tank? #6
ALAN
My boat's propane enclosure had two 3/4" inch holes sloped downward. One on each end of the enclosure at the lowest point.
For a land enclosure, I would probably go bigger, with insect screened vents in the bottom. Soffit vents would probably do nicely.
   / can i box in a propane tank? #7
Curly's ideas should be explored further. :D
But best be checking with the local codes and also the insurers as their standards may vary.:D
   / can i box in a propane tank? #8
I agree with Curly and Egon, maybe call your local propane dealer and see what they recommend.
Gosh, you can even get a tank that you can put underground around here if one desires it.
   / can i box in a propane tank? #9
You guys are worried about the wrong thing.
There is no danger in a properly bottom vented outdoor propane enclosure. Propane is heavier than air. Any leak will be safely dissipated to the ground. The real danger is in having propane inside the house, especially if there is a basement. If there is a leak in the line inside the dwelling, the lowest point in the house will eventually fill with propane. Flip on the basement light switch or have an oil burner ignite and boom.
If the propane tank is far enough away, the enclosure probably won't even be damaged when the house goes up.
   / can i box in a propane tank? #10
That cracked me up. Glad I was done eating lunch. :D:D:D:D
Later,
Dan
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2001 Chevrolet Suburban SUV (A59231)
2001 Chevrolet...
207274 (A52708)
207274 (A52708)
LIGHT TOWER (A56857)
