can i box in a propane tank?
   / can i box in a propane tank? #11
Here is my set up in use since September 2004. The vented structure holds two 40 lbs. cylinders.
MIKE ,
That sure looks a heck of a lot better than looking at the tanks.Thats just what i want to do ,enclose the oil tank and propane ,because they are such eye sores.
My propane company forbid me from painting my tank.Ialways painted it the same color as the house so it blended in.They said i could build a structure around it,but i didnt get details. Iwant to be safe so i think ill stick with you guys advice somewhat,and seperate the oil tank section from the propane and vent the propane part.Ill call the propane outfit too,to confirm this is ok
Thanks for the help guys good advice
ALAN
   / can i box in a propane tank? #13
Why not create a 'shed' using 4' x 8' lattice material, usually available from lumber yards.
Build a structure from 2 x 4's and tack on the lattice material and add a roof to drain water away from your house.
As previously stated propane is heavier than air plus with the lattice you would have virtually 50% ventilation.
I 'shedded' my oil tank in that way and feel completely safe with the setup.
   / can i box in a propane tank? #14
I have done this before. You can get creative with the lattice. You can also plant vining/creping plants that will cover the lattice in a season or two.
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
Mini Skid 6 Way Blade (A56436)
Mini Skid 6 Way...
2021 SANY SY365C9C5K (A58214)
2021 SANY...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Booster Cables (A59230)
Booster Cables...
