BrierPatch
Gold Member
- Joined
- Aug 12, 2008
- Messages
- 368
- Location
- West Central Indiana
- Tractor
- Kubota B2620 364 FEL, BH65, 60" MMM
I understand your position. Do you have any specific jobs lined up? Do you use a chipper for your own mulch or composting? Do you have much expierence with a chipper. I have a small chipper and after using it once or twice I realized I was spending alot of time getting little done. It is much easier and quicker for me to burn brush instead of chipping it. Burning my brush has now turned into an annual event for freinds and families, weenie roast. Keep in mind I don't have expierence with a larger pto chipper. BH are hard to justify the cost. I paid just a little more than the cost of just the BH65 when I bought my full size IH3616. That was my justification when I got it. I got a whole tractor, loader, BH that weighs 12-14K lbs for what just a BH attachment costs. Do you plan on doing some landscaping, ditching? Is your ground mostly flat or uneven? Sometimes you need a backhoe to grade something level when you cannot get the tractor level to use the loader. If you think you are going to just run some water, power, or drainage lines, the price of a BH will go a long way in a trencher rental, which is better suited for it, and you don't have to store it when you are done. I don't see it being a problem if you buy the 2620 with FEL and BH65 and 15% down 48mo finac. should put you roughly around $350/mo. The chipper option should be even less. You can use the FEL on the 2620 without any ballast although not really reccommended. You might consider a grader box or something else that is useful instead of a ballast box which is just for weight. Sorry to be long winded. So many options and there is usually more than one way to do something.
