can i box in a propane tank?
   / can i box in a propane tank? #11
Here is my set up in use since September 2004. The vented structure holds two 40 lbs. cylinders.
MIKE ,
That sure looks a heck of a lot better than looking at the tanks.Thats just what i want to do ,enclose the oil tank and propane ,because they are such eye sores.
My propane company forbid me from painting my tank.Ialways painted it the same color as the house so it blended in.They said i could build a structure around it,but i didnt get details. Iwant to be safe so i think ill stick with you guys advice somewhat,and seperate the oil tank section from the propane and vent the propane part.Ill call the propane outfit too,to confirm this is ok
Thanks for the help guys good advice
ALAN
   / can i box in a propane tank? #13
Why not create a 'shed' using 4' x 8' lattice material, usually available from lumber yards.
Build a structure from 2 x 4's and tack on the lattice material and add a roof to drain water away from your house.
As previously stated propane is heavier than air plus with the lattice you would have virtually 50% ventilation.
I 'shedded' my oil tank in that way and feel completely safe with the setup.
   / can i box in a propane tank? #14
I have done this before. You can get creative with the lattice. You can also plant vining/creping plants that will cover the lattice in a season or two.
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2007 Ford F250 Pick Up Truck (A59814)
2007 Ford F250...
2018 KOMATSU WA200-8 WHEEL LOADER (A60429)
2018 KOMATSU...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
1993 Ford Pick Up (A59814)
1993 Ford Pick Up...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
