Kubota Rear Work Light
   / Kubota Rear Work Light #1
K10
NH
BX1500
I am looking for a part number for the Kubota Rear Work Light? This I believe is from the factory and comes with the ROPS bracket and is set to go out of the box.
Thank you
   / Kubota Rear Work Light #2
I just put a pair of these OPTRONICS COMPETITION SERIES DRIVING LIGHTS - CarParts Quality Discount Parts and Accessories on my 5030.
I am highly impressed. They put out at least twice the light as my OEM Kubota work lights that I replaced. The write up on them on the web page is wrong. They are 50 watt MR16 bulbs; very bright and they come with wiring and switch. Can't beat the price either.
(since I was already wired and switched, I was plug and play.)
I am buying a second set to replace my rear oem Kubota work lights. I got the idea of mr16 work lights after I saw them on a Deere dozer.
   / Kubota Rear Work Light #3
Thank you
I think the Kubota part is BX7330. That is the Kubota single work light that clamps to the rops.
   / Kubota Rear Work Light #4
What particular tractor model? I have one still in the box; labeled whole goods parts #B7331, service parts # 6C040-955054. Made in Japan by II-shin, and fits, or has instructions for most B series models. Not much of a value for the money, unless you have one of the 4 out of 14 (B7410, 7510, 7610, or 7800) that require the separate ground strap and/or the special bracket; others just use an existing hole in the ROPS or existing ROPS brackets. You could but 4-5 similar rubber housed lights for the price of this one.
I have a BX1500 so I believe the correct model will be the BX7330. I will call the dealer to find out. Thank you.
   / Kubota Rear Work Light #6
Yes, I think the BX7330 is correct for a BX series, and if the pics shown in some of the older post are correct, it looks better than the simple lamp included with the B7331 kit.
   / Kubota Rear Work Light #7
There is nothing I have found not to like about it. The BX models are very well engineered and will do more than I would probably ever ask of it.
   / Kubota Rear Work Light #10
Have you had to replace the seals and the front 4wd axle pivot pin yet?
if so, how did you get the bushings out?
Grundfos Pump System (A50121)
Grundfos Pump...
2013 Ford F-350 XL (A50120)
2013 Ford F-350 XL...
2011 New Holland B95B Backhoe (RIDE AND DRIVE) (A50774)
2011 New Holland...
43020 (A51691)
43020 (A51691)
35in Tooth Excavator Bucket (A50322)
35in Tooth...
Vicon RV1601 Round Baler (A50774)
Vicon RV1601 Round...
