Kubota Rear Work Light
   / Kubota Rear Work Light #1
K10
NH
BX1500
I am looking for a part number for the Kubota Rear Work Light? This I believe is from the factory and comes with the ROPS bracket and is set to go out of the box.
Thank you
   / Kubota Rear Work Light #2
I just put a pair of these OPTRONICS COMPETITION SERIES DRIVING LIGHTS - CarParts Quality Discount Parts and Accessories on my 5030.
I am highly impressed. They put out at least twice the light as my OEM Kubota work lights that I replaced. The write up on them on the web page is wrong. They are 50 watt MR16 bulbs; very bright and they come with wiring and switch. Can't beat the price either.
(since I was already wired and switched, I was plug and play.)
I am buying a second set to replace my rear oem Kubota work lights. I got the idea of mr16 work lights after I saw them on a Deere dozer.
   / Kubota Rear Work Light #3
Thank you
I think the Kubota part is BX7330. That is the Kubota single work light that clamps to the rops.
   / Kubota Rear Work Light #4
What particular tractor model? I have one still in the box; labeled whole goods parts #B7331, service parts # 6C040-955054. Made in Japan by II-shin, and fits, or has instructions for most B series models. Not much of a value for the money, unless you have one of the 4 out of 14 (B7410, 7510, 7610, or 7800) that require the separate ground strap and/or the special bracket; others just use an existing hole in the ROPS or existing ROPS brackets. You could but 4-5 similar rubber housed lights for the price of this one.
I have a BX1500 so I believe the correct model will be the BX7330. I will call the dealer to find out. Thank you.
   / Kubota Rear Work Light #6
Yes, I think the BX7330 is correct for a BX series, and if the pics shown in some of the older post are correct, it looks better than the simple lamp included with the B7331 kit.
   / Kubota Rear Work Light #7
There is nothing I have found not to like about it. The BX models are very well engineered and will do more than I would probably ever ask of it.
   / Kubota Rear Work Light #10
Have you had to replace the seals and the front 4wd axle pivot pin yet?
if so, how did you get the bushings out?
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Rears 500 Gallon Orchard Sprayer (A50120)
Rears 500 Gallon...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
Erie Industries GF480 Rolling Seperator (A50121)
Erie Industries...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
