New Holland vs. Kubota
   / New Holland vs. Kubota #21
I owned a kubota b2710...a pretty nice tractor in the kubota lineup ( compared w/ the b7800 at the time). I started shopping for my replacement kubota when the family moved to a larger property. Orange was for me, as my tractor was awesome....:D
I then discovered New Holland. :cool:I now own a TC45D with supersteer. Beyond the 18 HP difference, the NH offered rear remotes (stock), supersteer, pivoting seat, 4 sp hydro (turtle-rabbit in 2 stage transmission), turtle-rabbit button on loader stick, much better operators platform (loader stick location, and all other stuff including no more trying to fuel the tractor with a loader support in the way...), and far superior hydraulics.
Both tractors are very good, for me though, NH is a much better machine. I've put 500 hours on it in the last 2 years, and have had only self-inflicted issues :eek:. A TC45D is a great machine.
Best of luck...
   / New Holland vs. Kubota #22
I
Look at fueling ease - my tractor fuel tack cap is on the hood - i.e. no fun lifting a 5 gal. tank to re-fuel. .
My NH TN70A has the fuel cap on the back end. Very easy to refuel with 5 gallon cans. Until you mentioned it, I never gave it any thought.
Bob
   / New Holland vs. Kubota #24
Bob
Not only convenient to get to but a very large diameter. My Ford 2120 has the "normal" size filler mounted in the center of the hood and it is a royal pain.
Andy
   / New Holland vs. Kubota #25
I've owned Fords with the hood tank, my Kubota has a hood tank, and the Case/IH we had had a behind the seat tank. All a royal pain to fill when you burn 20 gallons a day and buy fuel in 5 gallon jugs. The underbelly tanks might require a lift pump and get a stick through them every so often but boys is it nice to fill.
We did used to use a pump off a tank that eased the pain but it somehow would attract water like nothing else.
   / New Holland vs. Kubota #26
the Case/IH we had had a behind the seat tank. The underbelly tanks might require a lift pump and get a stick through them every so often but boys is it nice to fill.
My NH 2003 TN70A has both an under belly tank and a filler pipe behind the seat. The underbelly tank has a skid plate that protects it from damage. This was an option on my year. I think it maybe standard equipment now.
Bob
   / New Holland vs. Kubota #27
either way you can't go wrong.
Go with the Dealer who's going to take care of you and your needs for service and parts for Maint.
While your at consider JD too.
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
2017 JLG 1932R 19FT Scissor Lift (A50322)
2017 JLG 1932R...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
KENWORTH VIN - (A50323)
KENWORTH VIN -...
Deere 304K (A50120)
Deere 304K (A50120)
