need to vent
   / need to vent #11
In the dealers defense, doing a neat job takes more time. You definitely should have asked for a written estimate, as was stated. I recommend using your frustration to remind you in the future to learn to do more repairs yourself, and get a little more intimate with your tractor. FWIW, $75/hr would be cheap for shop labor around here.
   / need to vent #12
75/hr is what the nearby dealer in Buffalo charges. Anyway, the lights look really cool, and man are they bright. I think they'll do a great job for you. In time I'm sure you'll forget about the price.
   / need to vent #13
Hind sight is 20/20 of course...Personally I would have had an estimate before pursuing it...The lights look Great though.
Don
   / need to vent #14
Well i know that i have not posted lot but, i need to get this off my chest and maybe you have some horrier stories to tell. this morning i droped my bx24 off at my local kubota dealer (bucks county, Pa) to have 4 flood lights put on becuase i thought they would already know the best route to run the wiresso they dont get snag on anything. So I head up to the dealer at 4 to pick up my tractor smile on my face and then they hit me with the total. 556 dollars for 5 1/2 hours of work. They had to make the brakets but i suppled the lights and they had the rest of the switches wire and fuses.
What I am getting at is i thought I could truss my dealer to take care of me not take a weeks wofth of pay away from me. the work they did was good but didn't know that their lowest rate was 75 a hour and the electrical work per hour was more. This is the last time they will lay a finger on my tractor!!
Thanks for reading
you should have gotten a price first.
   / need to vent #16
On the bright side, it looks like a quality job and they sure will give you lots of light!! And there wont be any issues with warranty in the future.
Neatness takes time and unfortunately that's gonna cost .
   / need to vent
i am goning to call the dealer owner tomorrow to see if there is anything that can be done (a little money back, i still think i paid to much) i want to have a good relationship with my dealer. time will heal all wounds
   / need to vent #18
I don't know if i should tell you this but the lights are on the wrong way.
The dealer should know that.
The beam on that kind of light should go right to left not up and down.
If he was going to place them sideways they should be round lights. Why would you want a beam 10 feet up in the air and 4 ft wide, I could be wrong so try it at night. I would mount them on the top of the rops
use the same bracket just put the bracket on the bottom of the top rop, the lights will be the right way and it would look better. Put the bracket on the bottom and the light on each side of the rops wires down.
That is a two/3 hr job .
   / need to vent #19
I am sorry but 5 1/2 hours. They must of waited 3-4hours for the paint to dry on the brackets.
2 brackets made(measured,cut,drilled) - 20 minutes
paint and dry time - 20-30 minutes
run wire, switches, etc - 1 hour max
mounted lights and test - 15-20 minutes
So 2-3 hours max.
   / need to vent #20
I would have preferred soldered connections and heat shrink instead of those blue crimp-on connectors. Maybe there is a functional reason behind it that I don't quite grasp. You'll certainly be able to see where you're going though it cost you dearly for the privilege.
72in Dual Cylinder Grapple Skid Steer Attachment (A51691)
72in Dual Cylinder...
2019 Kubota RTV-X1140 4x4 Utility Cart (A51691)
2019 Kubota...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2019 Ford F-150 XL (A50123)
2019 Ford F-150 XL...
