Another what's this worth question
   / Another what's this worth question #1
Treemonkey1000
Renton, Washington
Kubota L3750
This brush hog is on a local auction site. Right now I have the high bid of $80. Not that I need it really. Here is the description:
48 Rankin Brush Hog PTO driven Mower
S/N: 01022150
PTO Driveline included in auction
3-Point Hitch Type
Non-stationary blades
Dual blade mower
Never flat tires
Dimensions: 72 x 50 x 34
Weight: 470 lbs
   / Another what's this worth question #2
Look at it this way.
You are only paying $0.17 per lbs.?
   / Another what's this worth question #3
The rust appears to be mostly cosmetic. The unit is bent up pretty good on the left side it looks like. I would go maybe 200 at the most. The first thing you need to do if you get it is take that bolt out that is holding the pto shaft to the gear box and put the appropriate shear pin back in there. (I would imagine that is what is supposed to be there)
Yeah I noticed the "Shear pin"bolt. There is about 1 more day left on the auction. LIke I said I really don't need it but it is fun to bid on things and get a good deal once in a while. It does look like it has been well used.. Let's see aluminum is going for .25cents a pound. So at .17 cents would be about right for scrap iron:eek:
   / Another what's this worth question #5
From here that looks like a Cat 5 bolt for a shear pin which as you said is a problem. Of course on the other hand, I'll bet you don't have to replace it that often.
   / Another what's this worth question #6
Does it have a stump jumper. Is it 540 PTO.
Bill
   / Another what's this worth question #7
I thought the PTO shafts with shear bolts had the shear bolt on the front part of the shaft with a fitting with bearings in it. That way if the bolt breaks the shaft isn't flying around all over? If not I would be putting a clutch on it.
   / Another what's this worth question #8
$80 sounds cheap. I'd expect the serious bidders to wait until the last five minutes with their bids.
Eddie
   / Another what's this worth question #9
Lee, it may not be the right bolt, but it's in the right place. The end of the shaft coming from the gear box should have a groove with a split ring retainer that keeps the shaft from coming loose if the shear bolt breaks.
Yes the bidders do wait until the end sometimes. Right now it is at $102. It does have the stump jumper wheel. Here are a few more shots. You can see the metal that has been torn. That probably could be welded up easily enough. If the price goes for more than about $150 or so then I will pass. I can borrow one from a friend that is about 20 minutes away if I need one.
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
JLG 1255 Telehandler (A52128)
JLG 1255...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
