Fixing a junky plow.
   / Fixing a junky plow. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
A while back my B-I-L told me there was an old plow in his junk pile. Sure enough, there was a modren (as in not one of the good old ones) plow like you might find at TSC. It was rusty but still functional. Both hitch pins were bent to heck indicating hard use in the past.
Anyway, I've used this thing for about a year and thought I was just a dope because it took me a long time to get it set up properly each time I plowed. But, I did get decent results.
Well, a month or so ago I got to looking at this thing more critically after reading a comment by FWJ about bent plows. And sure enough, one of the frogs is not only bent outward a bit, but it is al twisted. The twist is minor but the bend does cause the plow point to turn outwards some.
I don't know if this was there from the start or if I bent it myself.
Anyway, after a week of the penetrant on the rusty bolts, I finally got it apart. I banged on that frog for 30 minutes with a hand held sledge (my most sophisticated and only metal working tool) and as far as I can tell did more damage to the sledge hammer than the frog.
I showed it to my B-I-L and he said he could heat it up and work on it but that it probably wasn't worth the price of the acetyline (or whatever), which to me means he doesn't want to fool with it...which is fine.
So, is there a way to fix this thing that is worth the expense since this plow isn't so great to begin with? I did contact the maker....they no longer make plows, no longer stock parts although the shares, shins and moldboards are "Ford type".
Here is a picture of it. The bent frog is the one on the right. You can't see much of an effect but the tip of that share does point a little too far to the right. You can also see that it is a pretty generic plow and otherwise not in terrible shape.
   / Fixing a junky plow. #3
If it uses Ford wear parts, the frog SHOULD be the same as a Ford frog. Many folks will pull a third (or even forth) bottom off a bigger plow to make a 2-bottom. I'd suggest running an add (over on YT for example) searching for a used Ford frog. Doubtful the wear parts are bent.
Also, try Leinbach. Their plows use Ford spec parts. (actually an old Pittsburg plow design, many of which were built by Oliver/White under contract for Ford) You IGHT be able to et a frog through Leinbach.
Before attempting that, I'd disassemble BOTh existing bottoms and determine if the shanks are still on the same plane and one ISN'T twisted.
The Leinbach does look very similar all the way around. So that's a good idea. I've talked with them about other things and they are very helpful.
You lost me there. Which part is the shank?
   / Fixing a junky plow. #5
I think, its the part that is vertical (as seen looking down the back of the tractor) and attached with 2 bolts see in the pic above (as slanted toward the front of the tractor). what all the wear-surface parts bolt to.
much more likely that that plane ol hunk of steel is bent than the hardened wear surfaces. Generally the wear surfaces will shatter if you hit a hard rock or something with a tip. (or you bend a shank)
Oh, I thought that was the frog. Probably got my terms mixed up, but that is the part that is bent. It must be 3/4 of an inch thick. The wear surfaces look quite good. I have hit quite a few rocks and have popped the shear pins on a stump or two. One stump stopped me cold. So I may have damaged it myself, but like I said, the hitch pins, and their attachment points were bent all to heck before I ever used it so someone, probably with a bigger tractor than mine, had already given it a pretty hard time.
I wonder how much a welding shop would charge to heat it up and hammer the bend out of it? Would that weaken it a lot?
   / Fixing a junky plow. #7
If it will come off completely take it to a shop with a press and have it straightened. I would not heat it unless it the last resort. I have a KK plow that looks very similar also.
Mine is similar to this one but mine has not bolts except for the trip and shear pin. It actually looks just like yours except the angled piece on the 3 point assembly is welded where yours is bolted.
http://www.kingkutter.com/WholeGood.asp?item=Plows
Chris
Where would you find something like that? Body shop maybe?
   / Fixing a junky plow. #9
no body shop is unlikely to have a press.....
likely a machine shop. or welding shop. Your local whatever farm/tractor dealer that does service is likely to have a HUGE press... might talk to one of the techs in the back about it. (guy at the desk is unlikly to have a clue what your talking about)
   / Fixing a junky plow. #10
The shank is leg portion of the frame. The part that swings back when the shear bolt does it's thing.....
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
74in FEL HD Round Back Bucket (A52748)
74in FEL HD Round...
TRUCK FLATBED (A52472)
2015 Nissan Sentra Sedan (A50324)
2015 Nissan Sentra...
