Kubota RTV Bedliner
   / Kubota RTV Bedliner #1
Jw5875
Gold Member
NW Pa.
Kubota L3400
I m planning to have the bed of my RTV 500 sprayed with the "Rino Hardline" product.
Has anyone else had this done to their RTV? I think that it will be better than the standard bedliner that Kubota lists (trying to find a price on one).
jw5875
   / Kubota RTV Bedliner #2
I looked into a liner vs spray in liner from Ziebart last winter, the spray in was in the $225 range (almost like a truck) and a drop in genuine Kubota bed liner was in the $150 range, as I recall. We went with the drop in liner and has up very well (we were picking up rocks in the field after tilling).
   / Kubota RTV Bedliner #3
jw5875
I rolled on(painted) my own bedliner with a product called herculiner on my 2006 RTV 900.I sanded the bed by hand and put on 1 coat of the herculiner,waited about 4-6 hours and added another coat.Total cost around $80-$100 bucks.I have had rocks,wood and steel in the bed no issues yet.coobie
   / Kubota RTV Bedliner #4
i had mine line-x'd and was thoroughly impressed with the process.
they "rough up" the bed before spraying the goop, and the whole process (3-4 hours) in the end made the price seem worthy.
do it once, and do it right!
oh, too, i got the 'bota drop in liner to boot -- it lets stuff slip out, whereas the line-x sticks its cargo.
   / Kubota RTV Bedliner #5
I got a 'stall mat' at Agway, It is about a half inch of tire like rubber,cut to fit with a sharp utility knife and held it in with two toilet bolts in the front. Keeps tools from sliding around,quiets things down and really protects the bed. Haven't had any problems dumping the load and can remove the two bolts to take it out if needed.
   / Kubota RTV Bedliner #6
just watch out for water getting trapped in there -- it'll rust the bed -- :(
   / Kubota RTV Bedliner #7
Although they often can be considered slippery I like the bed liners over the spray in. They normally protect the box from being damaged when things are thrown into the box and you won't get that with a spray in or roll in type of protector. The bed liners I've not had mositure problems under even with open tops and boxes will look good often nearly new when removed. Try that with a coating!
   / Kubota RTV Bedliner #8
I used 3 full Herculiner kits in the bed of the RTV900 I had and it still wasn't 1/4 as thick as the Rhino Liner I had sprayed in my other one. The Rhino Liner ended up actually being cheaper and oh so much thicker than even 3 full Herculiner kits I bought at Auto Zone. Obviously I want something thick.
If you look back in the threads, I'm also the guy who bought a factory Kubota drop in liner and removed it after a month. That's the RTV I put the 3 Herculiner kits in after removing the plastic drop in liner. That darn drop in liner rattled so bad I couldn't stand it. It's my opinion that a drop in liner provides the best protection against impacts, but it rattles so much and everything slides around. And, yes, after only a month in my RTV the drop in liner had worn the paint off a lot of the diamond plate ridges in the bottom of the RTV.
I have a Line-X liner in my RTV1100. I paid them to put it on extra thick but it's still only about half as thick as the standard Rhino Liner. I can't say that I've had any problems with the Line-X, but it definitely isn't as thick. It actually seems to be a harder compound than the Rhino Liner and the roll on Herculiner. Maybe that's why it isn't as thick. Still, for the price, I was pretty upset. They got out their little thickness gauge and "proved" to me that my Line-X was twice as thick as what the standard application is. Oh well... After having a drop in liner, 3 full kits of Herculiner, Rhino Liner and Line-X I'd have to say that the Rhino Liner would be my future choice.
   / Kubota RTV Bedliner #9
I did the DIY home roll on kit that was 75-80 bucks. About 1/2 way thru, I realized that it would have been worth it to get it done professionally. Man that's a lot of effort and the end quality isn't as good as the pro stuff. Total savings was about $100.
It has held up well, it's just a PITA to do!
   / Kubota RTV Bedliner #10
je5875, I had the Rino liner sprayed into my 900 about a year and a half ago. It is great! It's quiet, tough and trouble free. I have hauled rock, wood, barbed wire, steel and wood posts many hours over very rough roads with no damage. It also seems impervious to chemicals ( gas, oil, solvents, ect). To me it was a good investment of $200.
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
Zero Turn Mower (A59231)
Zero Turn Mower...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2018 Ford F-550 4x4 Altec AT37G Forestry Chipper Bucket Truck (A59230)
2018 Ford F-550...
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
