PM for a 500 Mile Round Trip
   / PM for a 500 Mile Round Trip
interesting project. This oughta keep you busy for awhile and out of trouble.;)
in the last picture you posted, I am concerned seeing a crack that large in the frame. Can you elaborate on that crack, any plans to fix it ?
The crack had been completely covered by the truck (as I now know it's called). When I saw it after I had the trailer taken apart, I about had a heart attack. On closer inspection, however, I saw that the back side of the crack has been welded, and there's a strap welded on to the bottom of the trailer as if to take the stress off the crack.
If I were to fix it, I wouldn't do much more than has been done. I may run a bead down the outside of the crack just for practice.
I put the zerks in tonight. I wonder if I'd have been better to use a 11/32" bit. I'm not very experienced with tapping threads, and the hole being slightly smaller than it should be really made for a tough go of it. All is well, though. I pushed some grease through the bolts via the zerks to push out all the metal drillings before assembly.
I'm going to put the trailer together tomorrow when I have some daylight.
Done.
   / PM for a 500 Mile Round Trip #104
Yeah, 11/32 prob would have been OK. Since NPT taps have such a taper
to them (unlike NC, NF taps), the hole size is not critical and the deeper
you tap, the harder it gets.
Once I used press-in zerks. I never will again....only tapped zerks for me!
2005 Kubota ZD21F Zero Turn Mower (A55851)
2005 Kubota ZD21F...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2024 John Deere 8R 410 MFWD Tractor (A53485)
2024 John Deere 8R...
